hv maxx motor issues!!! locked rotor
  • skidooguymxz550
    • Jun 2007
    • 242
    ok, i'm getting really annoyed. i'm running a hvmaxx in my offshore rcboat and it runs fast as hell but the most i've gotten 5 runs on it
    the first time it fried and i sent it in for a refurbed unit. that was after 4 runs with no thermals.
    when i got the new system in i got 5 runs with no thermals till once it stalled and quit in the water on me.
    i pulled her out and the problem is locked rotor detection. i pulled it from the boat and it still detects a locked rotor. when it's out of the boat though if i ease on the throttle i can get it to run. it will not run at all with a load on it.
    does anybody know whats causing this? please help!!
  • hammertime
    • 513
    samr thing happened to my ss system in my hammer........dont know what causedes it but i think it has something to do with it getting wet
    60% of the time... it works every time!
    • skidooguymxz550
      • Jun 2007
      • 242
      i looked at the paper work. it said exxecive heat will cause rotor and magnet damage. i'm sendn her in and i ordered a feiago water jacket for future prevention. hope it fixes it, cause to get the speeds i want out of the boat from convential marine power it would take alot more than you standard fieago xl
      • hammertime
        • 513
        i diagree......there will be more tourque with a feigao motor........more speed..........
        • NorthernBoater
          • 811
          I also disagree. The XL is a longer motor. That will produce more torque.
          • SJFE
            • 4735
            Guys I learned an expensive and hard lesson when I returned to rc boating. 95% of car power systems are not adapted well to boat. Just my 2 cents.
            • part time
              • 154
              sounds like it got too hot and the rotor lost its magnetism. this would still allow it to turn without a load but not with one. even with the water jacket it wont last much longer. IMO u are wasting money on the hv get a feigao and be done with it.
              • skidooguymxz550
                • Jun 2007
                • 242
                mmmmm...... those are good words to ponder
                • hammertime
                  • 513
                  i agree those novak systems are no good for boats......... i learned that the haaaaard way was well
                  • skidooguymxz550
                    • Jun 2007
                    • 242
                    ok. we're going to get the fieago and 120amp hydra
                    the hv maxx is going in my sandrail.........
                    going to be full metal when finished
                    • Jeepers
                      • May 2007
                      • 1973
                      I am gonna have to disagree with this, these motors are not good in BIG boats, but they are VERY good in the right size hull, we have one in our club he is using a Novak GTB 7.5 in a 21 inch hydro spins a modified x432 and the little thing is ballistic it has no problem hangin with in LSH hydro and it runs forever on 6 4200s. it has gotten wet many times he dries it out with compressed air and throws it back in the water.
                      • ROOSTERTAIL
                        • Jun 2007
                        • 34
                        The NOVAKS will work just fine in boats. BILL OXIDIAN has ran them since thier inception, He runs the NOVAK very regularly. HE HAS SET, BROKEN AND HOLDS SEVERAL RECORDS USING THEM, The key is to match the system to the hull This holds true to all powereplants,
                        • Doug Smock
                          Moderator
                          • 5272
                          If we only knew what Skidooguy's application was, maybe we could help. :D
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • skidooguymxz550
                            • Jun 2007
                            • 242
                            it's a 31" challenger. offshore deep vee. the motor makes it fly but not for long. like i said i ordered a fieago 14xl and hydra120 last night
                            i'll be taking a speed cut but the "trouble free" running will be worth it
                            • SJFE
                              • 4735
                              I was aware of there uses. I should have been more clear. My intent was to make it easer for the new guy. When you burn up equipment and waist money it discourages newbs and they drop out of FE before having any fun. As we all know using the right equipment early on makes for a better experience.
