supervee setup
  • blackcreeksv1
    • 10
    supervee setup
    currently im purchasing upgrades for my sv! will this setup be fine? max amps 2s2p 7.4 6500 mah packs with a ammo 2600, turnigy 120 amp esc w/bec and 40x52/3& 42x55 props! if not please make a good suggestion!
    thanks
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7119
    I would put 2S packs in series, you probably are anyway (4S1P).
    "Look good doin' it"
    See the fleet
    • blackcreeksv1
      • 10
      yes iam! i was just wondering if i was gona burn anything up!
      • Jesse J
        scale FE racer
        • Aug 2008
        • 7119
        If you check your temps after a couple laps and they are staying low, then take a few more and if after several checks they are fine, you should be ok
        your set up seems well within the limits. to be sure, check temps frequently until you are satisfied. Might want to use an infrared meter to get accurate readings.
        See the fleet
