2 blade vs. 3 blade
  • Norman2
    • Sep 2008
    • 321
    2 blade vs. 3 blade
    Hi, Is there any advantage in FE boats in using a 2 blade or a three blade.
    Thanks for any help,
    Norman2
    34" Ekos Cat UL-1 Powered
  • Raydee
    • May 2007
    • 1603
    Norman in my experience 3 blade props lose a little top speed but give you more grunt out of the corners. Some boats like my 33" mono just hate 2 blade props and run much better on 3 blades. Keep in mine that the extra blade equals out to be about one size up in prop diameter (or around there). So if you are running a two blade 42mm prop a three blade 40mm prop will yield about the same amp draw as long as the pitch is equal as well.
    Team Liquid Dash
    • NitroVal
      • Jun 2009
      • 423
      I think I read somewhere that a comparable three blade will create more drag in the water as well, especially on surface drives
      The RTR Nightmare- Electric King of Shaves
      Now with 540s- 62mph
      New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
      • Norman2
        • Sep 2008
        • 321
        Hi, Guys thanks for the info. I think I will keep to 2 blades. I now run Octura X640 and X642
        on a 30" Scratch built cat,(My Avatar)and 642 on my Titan 29" Mono.
        Norman2
        • BakedMopar
          No Mo Slipah
          • Sep 2009
          • 1679
          I notice on my SV the three blade prop hops less than my two blades in the corners. But then again maybe my setup is just all wrong.
