Hey I just noticed that with deans you can solder pos neg however you want as long as they are all the same. I recently got some batts with deans on them allready and they are opposite mine. does everyone go through this or is there a standard as to flat=pos or vertical=neg? I would suppose tamiya connectors would be the same way but i have never ran across having trouble with neg and pos with the tamiya connectors. If there is no standard someone should create one!
deans connectors
Tags: None
yeah makes sense, mine i dont think are marked. maybe they are but I plow right into stuff without directionsComment
They're marked. Look on the side where you solder to and on the flat part of the red where the pins go into the red you'll see a "+" on one and a "-" on the other.Comment
Best to keep it standard. The most important thing is that the female connector goes on the batteries. Less chance to short them out.ReddyWatts fleet photo
Mean Machine - Feigao 540 14XL, 8s, 100 amp HV esc, X537/3Comment
