Chemtronics conformal coating
  • rockwerks
    • Jul 2008
    • 772
    Is this stuff any good for coating our esc's I can pick up a can at the hardware store:
    10 OZ SILICONE KONFORM® SR CONFORMAL COATING ; PROVIDES PROTECTION FOR BOTH RIGID AND FLEXIBLE CIRCUIT BOARDS ; RESISTS MOISTURE, SALT, FUNGUS, CORROSIVE VAPORS AND WITHSTANDS HEAT GENERATED BY ELECTRONIC CIRCUITRY AS WELL AS CLIMATIC TEMPERATURES ; VOC 88.00 ; ODP 0.00 ; STABLE FROM -85ºF TO 390ºF ; DIELECTRIC STRENGTH OF 1100 VOLTS/MIL ; MEETS MIL-I-46058C, TYPE SR ; PRICED PER AEROSOL CAN AND SOLD 12 CANS PER ORDER
    like 30.00 a can
    an RC rock crawler lost in a sea of boat parts.........
  • RandyatBBY
    • Sep 2007
    • 3915
    I use MG Chemicals Confromal coating it is $21.00. I get it from Frys Electronics. You need to be careful of the contacts I use clay to keep the coating off the contacts. It is great for all circut boards.
    Randy
    BBY Racing
    • rockwerks
      • Jul 2008
      • 772
      contacts? esc's have contacts?
      • RandyatBBY
        • Sep 2007
        • 3915
        LOL! I was thinking recievers, Brain Fart. Ya you do not want to get it on your connectors either.
        Randy
        BBY Racing
        • rockwerks
          • Jul 2008
          • 772
          Well I just ended up with a case of the stuff and looks like I can sell it for like 17.00 shipped a can...................anyone need a can or 2 LOL
          • Tony
            • 413
            Which hardware store? HomeDepot, Lowes?
            • rockwerks
              • Jul 2008
              • 772
              a small ace hardware in WA. got a case because out here he never sold any so gave me a great deal on it, I bought all that He had
              • Steven Vaccaro
                • 8721
                I use a similar spray in certain places. It works well. I suggest spraying a few coats on the item you want to protect. Otherwise if its say a esc with no srink wrap, its possible that it will rub off a bit if only a single coat.
                • sailr
                  • Nov 2007
                  • 6927
                  Does this stuff dry hard or stay sticky?
                  Mini Cat Racing USA
                  www.minicatracingusa.com
                  • D&D
                    • Aug 2009
                    • 185
                    How does any product like this effect the ESCs temperature and what happens if you need to get the ESC repaired??
                    • Steven Vaccaro
                      • 8721
                      The stuff I use is dry.
                      • Steven Vaccaro
                        • 8721
                        Since its like a coat of spray paint it isnt to bad. If you have to repair a esc than it will be an issue to work around. The only esc's that really need something like this are the Asian ones, and those are replaced. Not repaired as far as I know.
                        • BILL OXIDEAN
                          Banned
                          • Sep 2008
                          • 1494
                          I'd say coating it thick enough is the key. I often spray a little into a tiny cup, let it thicken for like 5m and apply it with a paintbrush.
                          Yes some ESC units have contacts. ETTI speedos have an external 2pin plug for their RPM sensor.
                          Car speedos often have external rcvr lead terminals..
                          • Steven Vaccaro
                            • 8721
                            Bill thats why I suggest a few coats. but your way sounds like a good idea also.
                            Where I can I always use the epoxy for that reason. Just a thin coating around the fet area. Back in the day, when playing with the conformal epoxy, I have literally run brushed esc's under water when coated right. Where the spray works great is with an esc like the Jeti 600. The jeti comes with a 1 year warranty, so you cant mess with the shrink coating, so I just spray the hell out of one of the open ends and let it drip out the other end.
                            • BILL OXIDEAN
                              Banned
                              • Sep 2008
                              • 1494
                              Yeah Steve, you brought up the most valid point, spraying extra coats. One coat looks almost like there's nothing on there.
                              Most receivers on the market today (I know Airtronics does) use silicone conformal on them factory. With most electronics mfgrs using it will not void your warranty whereas the benefit of using it is also tat the unit can still be worked on (soldered), and with epoxy its MUCH more difficult and will likely void your warranty.
                              Epoxy works better than most anything I've seen, Rc Hydros speedos almost NEVER got water damaged
                              Etti Speedos use a thick silicone/rubber like material that I'd love to get my hands on some of. Coats thick like epoxy, but feels pliable and peels off quite easily for maintenance..
