feigao motor q wires
  • hammertime
    • 513
    which is positive and neg and the timing red pos yellow neg green tim
    60% of the time... it works every time!
  • NorthernBoater
    • 811
    There is no positive or negative. A brushless motor operates more like a 3 phase AC motor. Here is the article on Wikipedia.
    • part time
      • 154
      it does not matter. just hook them up in any order. if the motor spins backwards reverse any 2 wires.
      • hammertime
        • 513
        ok what would cause it to stop when pressure is on it
        • Diegoboy
          • Mar 2007
          • 7244
          Over amping the ESC or Batteries maybe.
          • hammertime
            • 513
            im running it with nothin on it outta the water.....i pull the trigger and it spin for 1/2 a sec then stops........do it again and stops
            • Diegoboy
              • Mar 2007
              • 7244
              Are you having to "re-arm" the ESC each time?
              What ESC are you connected to?
              What battery(ies) are you running?
              • hammertime
                • 513
                no rearming......... im just testing with a towerpro.........and some 1b3600s
                • hammertime
                  • 513
                  guess noone knows
                  • part time
                    • 154
                    i would say its not the motor. its sounds likes its a arming issue like diegoboy said. if u are using a pistol tx use a rubberband to hold the throttle at full reverse with all trims and epa set a zero. and reprogram it again.
                      NEVER NEVER NEVER run a BL motor at near full throttle out of the water without load. There is no good reason to ever do so. It is an almost sure way to cause damage if overdone. The motor may have stopped because it exceeded the ESC's maximum rpm rating. It could be a cogging issue with a cheap ESC (most likely, the ESC has trouble sensing the rotor position at low load). It may have developed a loose magnet. Don't do it again.
