gotta prob
  • hammertime
    • 513
    gotta prob
    ok my flex shaft broke in my coupler now its 2 short......i have another flex shaft but i dont know how to get the old one outta the drive shaft........ i used locktight........any suggestions
    60% of the time... it works every time!
  • Mich. Maniac
    Banned
    • 1384
    google loctite release, I thought I saw an agent for that. probly a fortune though.
    • NorthernBoater
      • 811
      Use a soldering iron to heat it up and remove the cable with a pliers. The fuel guys at the pond said that applying heat to it will loosen it up.
      • hammertime
        • 513
        ok great thanks
        • Eyekandyboats
          • 1921
          use a little torch until the loctite starts to bubble
          Most flex shafts will come with a stub unless you ordered otherwise
          EYEKANDYGRAPHICS
          www.rclipos.com
          • Gilbequick
            • Jun 2007
            • 140
            How'd it work for you?
            • SJFE
              • 4735
              If you cant use heat try soaking it in thinner or nail polish remover.
              • ReddyWatts
                • 1711
                Stick it in the oven for about 15 minutes at 200 degrees, then it should come out easily.
                ReddyWatts fleet photo
                • Steven Vaccaro
                  • 8721
                  Clean up is harder than the release. Make sure to use a small sanding bit on the dremal to get it nice and clean again.
                  • hammertime
                    • 513
                    you mean to clean the inside of the drive shaft
