Got a couple of lipo that got wet. Stripped the wrap, patted them dry, sat them under a fan overnight and had them sitting exposed for a week. They are as dry as they are going to get and the heat shrinks arrived today. Can I use plasti dip (pictured) to cover the ends after the shrink wrap has been applied? Is waterproofing advisable? Should I be worried about possible moisture retention?Thanks!
Waterproof a lipo pack???
I think we had a thread about it here somewhere and it basically was saying that "sealing" the packs is not advisable because water WILL FIND A WAY IN and it'll not dry, creating rust and potentially a broken tab or a short somewhere...
so my advise to you is, seal the hull well not the battery packs.
I personally sunk many batteries in the water, made sure to dry it out nicely and they worked just fine, you'll find that many people have done the same.:::::::::::::::. It's NEVER fast enough! .::::::::::::::: -
I personally sunk many batteries in the water, made sure to dry it out nicely and they worked just fine, you'll find that many people have done the same.I'm glad I got 5 feet of heat shrink
Thanks!Comment
insulate & seal'em
Hi Mate ,
with my 32' Cat i have insulated the 2x 4s parallel wired & sealed the packs with silicone where the wires protrude through . Considering the amps i run does not allow for over heating , i find this to be a most effective measure in maintaining battery intregity . Works for me anyway .....
All the best in R/C Boating
BradRoy Cooper's www.fastonwater.co.uk - Where Brittish Raceboat History Comes To Life !!!Comment
