Colored Carbon Cloth?
  • Steven Vaccaro
    • 8720
    Have any of you guys used the multi colored carbon cloth as a strengthener on a hull bottom? Seems it would look cool in a hull. But I haven't seen it used much.
    carbon fiber hybrid spectra graphite kevlar carbon fiber graphite kevlar carbon fiber graphite kevlar aramid cabon fiber
  • rockwerks
    • Jul 2008
    • 772
    http://www.shopmaninc.com/hybrids.html
    I have used a bit of it, there is a guy on ebay selling it alone with matching or contrasting resin
    an RC rock crawler lost in a sea of boat parts.........
    • Bill-SOCAL
      • Nov 2007
      • 1404
      It is used a lot in airplanes, especially high end gliders. Looks very cool and is just as strong as black CF. Keep in mind that it is usually a weave fo CF and Kevlar, which makes for a very strong fabric.
      I have several big thermal duration gliders that get slammed in to the landing circle very hard for landing and the fuses hold up great.
      Don't get me started
      • tth
        • Apr 2008
        • 1510
        I am not 100% sure but I read that the Kevlar is pretty hard to form around the curves. I know I love to use the carbon and it looks sweet!!! If someone did use the carbon/kevlar I would like some feedback too. I could get the colors to match my hulls.
        • Steven Vaccaro
          • 8720
          thanks, I just noticed the part in the ad that said its hard to cut without the special scissors.
          • Bill-SOCAL
            • Nov 2007
            • 1404
            Yep, forgot to mention that. I am also not certain how well it works with polyester resin. Everything I have seen it done with used epoxy.
            • JimClark
              • 5907
              The kevlar also frays when you cut into the hull. I had it in my Version 3 of Miss Bardahl. the bottom was rock solid for sure butit was a problem when I had to cut the stuffing tube you couldn't get a real clean edge and I have to make sure I resealed it and soaked it in epoxy.
              Jim
              Billy Graham
              • bustitup
                • Aug 2008
                • 3071
                Jim
                if you take hair spray and spray the edge area of what you are cutting and let it dry....it helps this problem 100%
                • sailr
                  • Nov 2007
                  • 6927
                  The stuff looks really cool but some of the things I have read about Kevlar drives me back to the all carbon fabric. If you get the 2 x 2 twill pattern, it has a 'coolness' factor all its own.
                  Mini Cat Racing USA
                  www.minicatracingusa.com
                  • JimClark
                    • 5907
                    Actually it was after the hull was laid up and I was cutting the stuffing tube slot that it happened
                    Billy Graham
                    • Jeff
                      • 232
                      I use a fiskar's brand sissors from menard's. It is about 10" long and the bottom blade is serated. It holds the kevlar cloth very well. We have stopped using the kevlar because of the cutting and edge issues. It also tends to soak up a lot of resign and adds weight.
                      Steven, if you want some samples, Doug Peterson gave me his stock, have a little red kevlar and black carbon and a lot of the blue kevlar and black carbon. Let me know what size if you want some, it would be gratius for all you do for us boaters.
                      Jeff
                      I try and avoid paste eaters.
                      • teach
                        • Jun 2008
                        • 509
                        We have a club member that makes complete 1/10 scale hulls from carbon/kevlar. Super light and the corners are very sharp. He seems to really like the stuff. His hull also works very well. If you wanted more specific answers maybe I can have him get ahold of you.
                        • Steven Vaccaro
                          • 8720
                          Jeff
                          Jeff thanks for the offer. Hang on to it for now, I'm going to use some basic carbon I bought.
