Deep vee questions
  • rcjrboatman
    • Jul 2009
    • 40
    Deep vee questions
    As I've said before I am a newbie to FE brushless boating. I've done a plenty of boats in my day but not any brushless. I have a 33" ABS deep vee hull that I'd like to experiment with. Putting in the hardware is no problem but motors and batteries are another story. I picked up 2 motors cheap, both Hackers. One is a 7L and the other is a 13L. I also have a CC 120HV esc that I picked up at a reasonable price. My questions are as follows:
    Would either of these motors be ok for a hull of this size?
    What batteries would I use?
    What charger would be good to start with since I've not tried Lipos before?
    I have a power supply from the days of doing 24 cell nicad packs so a DC only charger is no problem.
    Are the 2.4 gig radios the way to go now? I've been seeing a lot about them.
    And lastly, where should I start with for a prop. I have a few around here and hope I might have one to start with
    I just want a mild setup to play with around here.
    After I am comfortable with this I will be trying other boats and of course going faster so I want to have a charger that will be able to charge bigger and better packs than what I start with.
    Any help is greatly appreciated. And thanks in advance.
  • Steven Vaccaro
    • 8721
    Not really, both are small for this sze boat. If I HAD to try one, I would try the
    540 13L. But for spot running you would be better off looking for a 540 9xl or 10xl
    What batteries would I use? 4s 20c 4000 or better.
    First, You should reasearch and ready about lipos before jumping in. The hyperion chargers are great.
    And lastly, where should I start with for a prop. I have a few around here and hope I might have one to start with.
    2.4 is working out great. Especially with the new Tactic systems.
    • Flying Scotsman
      Fast Electric Adict!
      • Jun 2007
      • 5190
      I will be more blunt than Steven....suprise....what is your budget, run time and speed expectations? As there are many options based on your reply. Do you have a picture or brand/model name of the hull.
      As a side note welcome to this forum and your endeavour to participate in FE boating
      Douggie
      • mickvk
        • Jun 2009
        • 213
        For testing hypothetical setups, this program is great: http://www.rcboataholic.com/fe_calc.htm
        Search this forum for more info on using it.
        • rcjrboatman
          • Jul 2009
          • 40
          The boat is an old Graupner Portofino. The first one, not the II. Speed- in the 30's Run time- 4 to 5 minutes Budget- no problem
          Thanks
