I was just wondering if anyone has tried this yet with this hull?
21 Phil Thomas with Spec power
Someone once mentioned that the larger Phil Thomas SS21 and Whiplash Sport 20 were both better handling hulls than the smaller UL-1 hull using UL-1 ESC/MOTOR combo.
SS21 left vs. UL-1 right........................................ SS 21 length measures 29 3/4"Last edited by detox; 09-27-2009, 01:49 PM.Comment
Thomas 21
My racing partner has one of the Thomas 21 hulls set up w/Aquacraft UL-1 ESC and motor and it runs very well and is much more stable than my UL-1. His is a nitro layup that he bought used. He did say it would be less work to build a Whip 20 than to fill all the pin holes in the Thomas boat. I think he goes by Toypainter on this forum.Comment
here is mine on 1515 1y power. Phil is laying up for me a second boat which will be p-spec power, some nice mods for this version. These are great handling boats.Comment
I quit experimenting with my SS21 because of the cold Winter weather. As soon as it gets warmer and less windy I will try UL-1 esc/motor combo. Boat was very fast with setup in picture and ran like it was on rails (COG seamed spot on).
http://forums.offshoreelectrics.com/...highlight=ss21Attached FilesComment
My Phil T has udergone numerous mods since the build thread and is running 100% better then it ever has. Instead of mounting a single 4s pack across the boat I am now running two TP 45c 2s packs either side of the motor.
http://forums.offshoreelectrics.com/...ead.php?t=7693
JimmyAttached FilesCome to the FASST sideComment
I went the forward route on my 45...works great too. packs either side of motor in rear.Attached FilesComment
I don't understand how this hull can run well with the CG back. The biggest problem with the PT21 as a P Sport boat is getting the weight far enough forward. With a 1515/1Y as far forward as possible and the packs shoved forward inside the sponsons the boat runs awesome, virtually never blows off. With a lighter AQ motor and the bats behind it, even at lower LSH speeds it would seem to be less than optimum....
Great build Jimmy, clean and sweet.
the CG is spot on .Comment
