typical wiring in parallel
  • Doug Smock
    Moderator
    • 5272
    Glad I could help, thanks guys.
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • teach
      • Jun 2008
      • 509
      Originally posted by D.Smock
      Here ya go Nick.
      Sorry for the dark pics, I'm no Jim Clark.
      Doug
      Sorry way OT but ya....that guy snaps amazing pictures!!
      • FloatDaBoat
        Bare Bones Fabricator
        • Sep 2009
        • 368
        I've used 20 gauge Magnet (motor rewind) wire to secure wires together for soldering. The solder won't stick to it, & can be removed afterwards, leaving a less bulky connection for a shrink tube insulation covering. I still prefer using a sleeve made from brass tubing, though. Tried to include a photo, but the download failed.
        • bustitup
          • Aug 2008
          • 3071
          Here ya go Nick.
          I bind the wires together with 18 ga. solid strand copper wire then solder them with a good hot iron. Get the job done and get out.
          If you need the wires to bend back over the control as I did in this case, keep that in mind before you strip and solder them. Make sure all the wires are the same length before you start.
          Hope this helps.
          Doug
          so now if i have this right..if i want to run 6s1p I would just take one of my 6s lipos and wire it to one set of red and black on the esc and leave the other set of black and red unhooked (but protected)?
          and for 6s2p I would take my two 6s lipos and wire each separate packs to there own red and black leads off the esc
          and for 12s1p I would take my two 6s lipos and wire them in series and then hook them to one set of the black and red off the esc and leave the other set of red and black not wired to anything (but protected)
          this is all correct after I make the wire mod that Doug shows above
          have i got it?
          • bustitup
            • Aug 2008
            • 3071
            email it to me and i will post it
            [email protected]
            • FloatDaBoat
              • Sep 2009
              • 368
              Sent the photo Nick, you may not receive it though, as I'm having puter problems on my end.
              • bustitup
                • Aug 2008
                • 3071
                got it
                • arnie84
                  • 236
                  #23
                  thanks for the info & pictures this thread has been great help to me also!!
                  • Jeff Wohlt
                    • Jan 2008
                    • 2716
                    #24
                    Mechanical connection is the way to go with the wire wrap. It could save folks from coming unsoldered and maybe save the ESC or cells and get back in.
                    How many time have we heard it came unsoldered.
                    www.rcraceboat.com
                    [email protected]
                    • Doby
                      KANADA RULES!
                      • 7280
                      #25
                      OK,,,Stupid question, why can't you just separate them. I have mine hooked up that way for the past 2 years with no issues?????
                      I don't recall seeing anything in Castles instructions either?? Maybe I'll have to go and re-read them!
                      Grand River Marine Modellers
                      • arnie84
                        • 236
                        #26
                        Im about to do it tonight, so if anyone can post why you just cant run the wires seperated pos & neg going to each battery not connected together like in the picture above would be great
                        • LiPo Power
                          DJI Drone Advanced Pilot
                          • May 2009
                          • 3186
                          #27
                          Same here Doby. I was running this boat like that for the season and no issues at all. This is 4S2P. It was installed before I got this boat by the previous owner. They had this set up running for a while also with no issues.
                          Robert
                          Canada
                          • Doug Smock
                            Moderator
                            • 5272
                            #28
                            Hey Fellas,
                            Page 1 Castle Hydra instructions.
                            "Make sure and connect the entire battery pack to both input wire sets of the Hydra 240.
                            Do not connect half of the battery pack to one input, this will lead to operating problems from potential voltage / current imbalances."
                            Doug
                            MODEL BOAT RACER
                            IMPBA President
                            IMPBA 19887L CD
                            NAMBA 1169
                            • Doby
                              KANADA RULES!
                              • 7280
                              #29
                              Could be taken also as connect one set of pos and negs to one battery and the other set to the other battery. As long as you run with both sets connected you will be OK, If you only run with one battery connected, then there could be issues.
                              Castles instructions are a bit ambiguous on this matter.
                              Joe Ford, where are you !!!!!!!
                              • bustitup
                                • Aug 2008
                                • 3071
                                #30
                                I allready asked Joe ford and castle tech also....they both will tell you what D. Smock just told you
                                DO NOT RUN WITH THE DOUBLE LEADS SEPERATED!!
