Aw man, I burnt up my Hydro-1 rigger. It looks like a Mini-Y/Starhip from Minicat Racing USA but it's actually a special larger model in the same line that's not normally available. I'm so mad. I had a blow over and didn't know I cracked my hull seam. Since it landed on it's feet I kept motoring and then KERPLOOOEY. Smoke is not good! I figured your morbid sense of curiosity would enjoy a shot from the morgue! Oh well, you gotta pay to play :)
Noooo - Viking Funeral!
I have had mild burn ups too
What is blown, burnt and dead ??
A motor will often survive, ESC's can be bought back after wet or heat.
Tell us what you have or more importantly, did have !!
This is not so that I can laugh, but so that I may learn.
Bummer on the fire and I do know what it is like.See it....find the photos.....sketch it it....build it........with woodComment
I WISH the hull survived. Hull failure was the cause of the electronics failure. I guess I can reglass the hull though...
Close. Like I said, it's the model named Hydro-1. It's a larger version of the Starship/Mini-Y.
Yeah, I hear ya. Akin to the flying lawnmower in aviation circles :)Comment
Bummer on the fire and I do know what it is like.Comment
Wow! Sorry to hear! Tape the seam where it split. Mix up some 1 hour epoxy and thin it to thick cream consistency with denatured alcohol. Make a good sized batch. Pour it into one corner of the hull and then rotate the hull around, letting the epoxy run around the seams. You may want to do a pour in a couple of different places. When it sets up, you hull will be stronger than ever.
Your motor may well be OK.Mini Cat Racing USA
I have one more of these left in White. She's pricey though. I sold that one to Mick at danged near cost....$500. These are a hot boat in Europe. Winning a lot of races in Hydro 1 class.Mini Cat Racing USA
EX President of the Offshore FE Vultures SocietyComment
- That's a Mini-y/Starship (420 mm) not a Hydro-1 (560mm).
- That auction is not eligible for sale in the US.
- That boat has a slower motor in it than the 3200kv available in the US.
- You may have heard of Minicat racing USA a few times in this thread.... They are the US Distributor
Yep. I have ONE of the Hydro-1's in stock. It's a MUCH larger version of the Starship.Mini Cat Racing USA
