esc opinions
  • hammertime
    • 513
    esc opinions
    i ordered a 8xl and the octura strudder from here........ what esc should i get........ i have asked about the pulso and i was thinking about the 100a........ trying to stay in a reasonable pricerange.........any opinions
    60% of the time... it works every time!
  • saleens7
    • 1108
    united hobbies has their hextronik 120amp esc for only 50$....the only thing is i think its out of stock and they sometimes take a while to get back in stock....they also have a couple other esc's that will work though...
    • LJH
      • 70
      UH is showing the Hextronic ESC as coming in on 7/17. Have one on order myself.
      Cheers,
      Jim
      • hammertime
        • 513
        would i need the pistix for this esc......and watercooling would be difficult too......and its not waterproof......thats why i was considering the pulso....watercooled.....waterproof.....and compatibale with the trigger radio.......... i wonder if the hex120 could use the sv cooling plates
        • Jeepers
          • May 2007
          • 1973
          what kind of boat you putting it in?
          • hammertime
            • 513
            im running this in my bk bandit s cat........12 cells maybe 14 12 first though......
            • hammertime
              • 513
              it is about a 30" boat
              • ED66677
                • 1300
                I have my 8XL on 36" mono running under 12 cells with a Mystery80A, got the last one for 10Euros on Ebay!
                Emmanuel
                • Flying Scotsman
                  Fast Electric Adict!
                  • Jun 2007
                  • 5190
                  Purchase a CC Hydra or an OEMRC Sentillon for up to 100-120 amps ...do not look at cheap ESC's such as Hextronic..my 2 cents!! Plus the type of boat, V hull , power, prop is important as far as ESC choice is concerned
                  Doug
                  • SJFE
                    • 4735
                    you will not need a pistix for the hex.
                    • Flying Scotsman
                      • Jun 2007
                      • 5190
                      You do require a Pistix for all Hextronic ESC's if you plan to use a pistol type rc unit
                      Doug
                      • SJFE
                        • 4735
                        Really doug...I have been running a hex 120 for months with my Dx3????
                        • Flying Scotsman
                          • Jun 2007
                          • 5190
                          I can not speak for 2.4 ghz radios and receivers, but Pistics are required for 75 mhz.
                          Doug
                          • SJFE
                            • 4735
                            Ahh I see. It must be a spektrum thing. I have noticed other issues that are solved by the 2.4ghz radio since I have moved over to it.
                            • Doug Smock
                              Moderator
                              • 5272
                              Is that right Tom?? Just plug and play???? No sub trim adjustments ect??
                              Doug
                              MODEL BOAT RACER
                              IMPBA President
                              IMPBA 19887L CD
                              NAMBA 1169
