We tried a new prop on our home made boat today, and the results seemed odd.
It's a 32" medium-V mono hull, with a 35/60 2300kv inrunner, with 2 x 2250mah 4s 20-30c lipo's.
From a stand-still it seems to churn the water, revving quite highly but not moving as fast as one would expect, but then it suddenly lifts up, gets on the plane and absolutely flies. There seems to be no gradual acceleration, as we've had with previous props we tried, but the top speed is mental!
This is an Aluminium (or should I say Aluminum) 1818 Mocom prop. Previous props we've used were cheap crappy plastic ones, just to get an idea of the right size, but when we uprated the batteries the boat would tear the blades off them in the first 30ft of accelerating.
We're not sure if we need a bigger or smaller diameter, or deeper pitch - this prop is only about a 1.1x pitch, being 47mm with 52mm pitch.
I know we should really be using surface props, but the shaft is an M5 thread (the boat was never meant to go this fast, but you know how it is
) so it would mean a complete new drive system, as no surface props seem to come with M5 screw fittings.
Any suggestions welcome (preferably not two word ones ending in "off" though).
Cheers,
Matt
PS. In case it helps, here's a link to a short youtube video of the boat when we were using a single lipo.
Cheers,
Matt
