Need help
Need help
I need a lot of HELP PLEASE. I just orderd Delta Force Sniper 45. I think maybe it was wrong size boat to order. I have a Lehner 2280-10 turn can I use that motor or is it to small ? If I can use this motor how many LIPO cell will it take?
Tags: None -
The motor you have should run on 10S voltage. The big Sniper is pretty large for that motor but it can be made to work if you are not expecting ballistic speeds.
While it may be a bit late now - and I am not trying to be mean - but you really should research a bit better before spending you money. You already have a motor - but you don't know the voltage or the size model it fits? You buy the boat not knowing if it is the right one for the motor you already have? What will you do about an ESC? Do you have a pond large enough to run this large, fast model?
There are a lot of folks here on OSE who can help you to not buy the wrong stuff - but you have to ask the questions first.
1527/1D is a very powerful/high amp draw 4S motor for boats 34" and under (if racing) or up to 40" if you don't plan on racing. It's a motor not for the faint of heart. It will burn equipment if not used perfectly.
The 2250/13T is a 6S to 8S motor and is much tamer than the 1527 1D. I've used this motor in a 6S setup: X445 or X447/2 prop in a 33" Titan mono with good success.
The 2280/10T is what you want for the Sniper IMO, on 10S as others have recommended. However, overall I don't recommend going that deep into an FE setup without some good FE experience under your belt. My 33" Titan setup above would be easier on the wallet and safer to set up and your chances of having a good FE experience will be greater than jumping into a 10S setup at this point in time.
Sell the Neu and buy yourself the remaining components to have a solid 6S setup.Comment
