can the jeti 600 esc run 2 motors? if so whats the limit on motor size?
question about jeti 600
Yes the Jeti 600 will run two motors. Your limit is not so much motor size, it is the load. The control is designed for 60 amps continuous, 70 amps for 30 sec.
What is your application??
DougMODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169 -
You would be better off with the rc hydros 10-32 for that application. Although there are people using am radios with the RcHydros controls. They do not recommend it.Steven Vaccaro
Where Racing on a Budget is a Reality!Comment
Ryin,
Maybe think about selling your Villian and getting a SV 27. I think you'll be better off , and much happier in the long haul.
IMPBA President
IMPBA 19887L CD
NAMBA 1169Comment
some things to consider about the villian; it was designed by an rc 'car' co. with the philosophy of it was complete as is(meaning it was not designed with upgrades in mind, you're supposed to fork over the cash and buy the faster item(car/truck/boat)), also designed to be mass produced(cheapest parts they could use, no part stronger than it absolutly needs to be). folks have reported that the boat/hull gets unstable at speeds over 25, one can compensate but, its expensive in terms of time and money. a scratch build will easily run more than $300(radio, hardware, motor/esc). where as for $320 you can buy a Super vee + a couple of grapner props and have a boat that will do close to 40 mph! w/o having to do much work. :) your choice. Note brushed motors will run around $35 each esc to go with $70-90Still waiting for my boat to come in.it came inComment
If you want the boat to handle rough water dont modify it. we tried one on 16 cells, (mostly just to kill it) and it had alot of problems handeling slight chop. this lasted for a whole 30 sec.:D
to increase stability on rough water get a bigger boat.Comment
the point is, if you want a boat that can handle rough water you have 2 choices. 1 settle for a boat that isn't much faster than 15-20 mph or 2) get a bigger boat 36" - 48"(3-4 feet long) the villian does what it was designed for, if you modify it to go faster it will not handle rough water.Still waiting for my boat to come in.it came inComment
