ESC programming
  • chunkymonkey28
    • Apr 2009
    • 58
    ESC programming
    Hey guys,
    Got a Himodel 125A for my boat project. I need to program it, and I don't know what to select lol. The motor is a Feigao 14L 540 sized motor. The battery is a 3S.
    I highlighted what I think should be correct.
    Options of set up:
    1. Cut-off voltage
    option 1. Ni-Mh battery, auto setup
    option 2. cut-off for 7S lipo
    option 3. cut-off for 6S lipo
    option 4. cut-off for 5S lipo
    option 5. cut-off for 4S lipo
    option 6. cut-off for 3S lipo
    2. Start-up mode
    option 1: auto set-up throttle range
    option 2: fixed throttle range
    option 3: high acceleration (hard start)
    option 4: low acceleration (soft start)
    3. brake
    option 1: no brake
    option 2: light brake
    option 3: medium brake
    option 4: heavy brake
    4. Running features
    option 1: default running direction
    option 2: reverse runing
    option 3: hard brake
    option 4: soft brake
    5. Timing modes ???????
    option 1: 2°
    option 2: 7°
    option 3: 15°
    option 4: 30°
    6. PWM modes ????
    option 1: 8K
    option 2: 16K
    Any input thus far would be great. The things I need the most help on are timing and PWM modes, or at least a definition of them
  • chunkymonkey28
    • Apr 2009
    • 58
    I figured out the PWM mode. So any timing help now would be great. I was thinking 7 degree timing to start with????
    • Flying Scotsman
      Fast Electric Adict!
      • Jun 2007
      • 5190
      7 degrees...no brake..soft start, my 2 cents on a controller I have never used
      Douggie
      • domwilson
        Moderator
        • 4408
        Being that it is a 2 pole motor, I would go with 2 degrees on the timing, option 1.
        Government Moto:
        • DISAR
          • Aug 2007
          • 1072
          2 degrees is safer, 7 degrees may increase your speed but motor will run hotter and more amps. Start with 2 and check temps, then try 7 and check again. No brake
          http://www.rcfastboats.com/
            • 9488
            Kinda like to jump into this thread, if that's ok..
            I have the 200A version in my Mean Machine and have noticed I am not getting full revs out of my motor?
            I have no idea why this is.. I put this esc in my UL-1 and pulled the trigger and noticed it does not have the peak rpms like the UL-1 esc..
            anyone have any ideas why?
            • Flying Scotsman
              • Jun 2007
              • 5190
              What motor, new or abused and what degree setting
              Douggie
                • 9488
                Douggie
                Thanks Douggie, esc is new ad I am using a 8XL new, timming is set to defalt.. I think that is 1* for 2-4 pole motors..
                • domwilson
                  Moderator
                  • 4408
                  In the manual. Does anyone know exactly what "Full Open" and "Full Close" mean? I would think that "Full Open" is the same as Full throttle.
                  Government Moto:
                  • 785boats
                    Wet Track Racing
                    • Nov 2008
                    • 3169
                    Chunky monkey.
                    I also set mine to option 4 in start up mode. I believe, from working with full size variable frequency speed drives with soft start, the start up current spike is a lot less. A bit easier on the ESC.
                    Definitely select the No Brake option. I am familiar with dynamic braking & generated voltages but Disar posted an article on it in relation to ESCs that puts the concept across clearly & concisely. Thanks Disar. Everyone should read this.
                    If the brake function is set to 'ON' The Himodel ESC automatically brakes for 3 seconds, I think, when you release the throttle.
                    If you simply google PWM you can learn as much or as little about Pulse Width Modulation as you like.
                    As others have suggested, low timing to start with. Its the only one I ever use. I've never tried higher myself though.
                    Brushless 55
                    Perhaps selecting 'Option 1' in start up mode might give you full range. It should be set at the factory as default setting, but ...Who knows?
                    Also I have heard that some transmitters require the endpoint adjustments to be taken out to 125% to get full range on some ESCs. I'm not sure personally, but someone will be able to advise on that .
                    Domwison.
                    I've always taken it to mean full throttle.
                      • 9488
                      not sure if this helps but I am using the stock radio from my UL-1 on my MM
                      • DISAR
                        • Aug 2007
                        • 1072
                        When I had this ESC with a Feigao 9XL, when changing the timing from 2 to 7 there was a very noticeable difference. Maybe it is a timing difference between the two ESCs.
                          • 9488
                          Ok, that just made me think of something
                          does the UL-1 esc have some timming in it?
                          maybe thats why their was a noticable difference..
                          • Flying Scotsman
                            • Jun 2007
                            • 5190
                            The Ul-1 Esc would be timed for a 6 pole motor, I presume?
                            Douggie
                              • 9488
                              Possibly then, the UL-1 esc is set to 7*
                              and my HM200A is at 1 or 2*
                              That would explain the difference!
                              Thank you
