Increase Motor KV or # of lipos
  • r1wheel
    • May 2008
    • 9
    Hi,
    Not sure which way to go? I want more speed, current setup 29" cat, KB45XL(1000kV) running on 6s with X648 prop, am getting just over 50mph.
    Temps are OK and pulling 90A average, 130A peak.
    I am now aiming for 60mph, is it possible with a 29" cat? If so do i keep the current setup and increase from 6s to 8s or change the motor from 1000kv to maybe 1200kV.
    Thanks
  • domwilson
    Moderator
    • 4408
    What cat hull are you running?
    Government Moto:
    • r1wheel
      • May 2008
      • 9
      Hi,
      I am running this cat:
      • txboatpilot
        • Oct 2007
        • 1494
        Try running 8s... I run a 6s Hydro with 1250-1500KV motors and a 8s Cat with 1020KV,, both will run easy 60mph...
        With a boat that size and wieght,, you will not pull too many amps on 8s1p.. You might want to prop down a little for the first run.. X648 should have you over 60 for sure!
        Nothing like keeping you lipos warm and your prop wet!!
        • DISAR
          • Aug 2007
          • 1072
          Also depends on what you have available, ESC for 8s? 4s lipos each for 130A discharge?
          If you do not have these maybe it is cheaper to buy a 1250-1500 kv motor, starting with smaller props.
          Txboatpilot's reply is very helpful since he already has these setups, depends on your available items and budget
          http://www.rcfastboats.com/
          • Jeff Wohlt
            • Jan 2008
            • 2716
            I also say step the KV up a bit and stay with 6S. 29" hull should be no problem getting to 60. Prop down a bit and let her spin. The cheaper way to go. You also do not need a KB45 amp hog to do it.
            www.rcraceboat.com
            [email protected]
