Question about BECs
  • NitroVal
    • Jun 2009
    • 423
    Question about BECs
    Im looking at the Castle 240 ESC ( http://www3.towerhobbies.com/cgi-bin...?&I=LXRJL6&P=7 ) and trying to make sense of how the BEC works.. Its list is as so:
    Cells w/ BEC: 5-12 NiCd/NiMH, 3S LiPo
    Cells no BEC: 5-20 NiCd/NiMH, 6S LiPo
    Does this mean if you wanted to run 6S, it would require an external BEC?
    The RTR Nightmare- Electric King of Shaves
    Now with 540s- 62mph
    New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
  • NorthernBoater
    • 811
    Yes
    You cannot use the internal BEC with 4s-6s.
    You need an external 4.8-6V source.
    You would need to pull the pin for the red wire.
    • NitroVal
      • Jun 2009
      • 423
      Ok, thanks
      • domwilson
        Moderator
        • 4408
        I thought that the Hydras were able to go to 4s using the BEC. Now it is only 3s?
        Most other controllers will do 4s or more with BEC. Are there others out there that are running hydras 4s or higher with BEC?
        Government Moto:
        • domwilson
          Moderator
          • 4408
          Is there anybody running the Hydras on 4s or higher with the BEC? If so, are you having any problems?
          Government Moto:
          • Flying Scotsman
            Fast Electric Adict!
            • Jun 2007
            • 5190
            Also, do not run a low voltage Castle ESC on 6S...5S max ...4S is a better option and buy your ESC from OSE
            Douggie
            • domwilson
              Moderator
              • 4408
              Yep..I bought both of mine from OSE. Got some sweeeet deals from Steve.
              But back to the BEC thing...anybody?
              Government Moto:
              • Flying Scotsman
                • Jun 2007
                • 5190
                Dom, I use an external power source on all my ESCs regardless of power.
                Douggie
                • domwilson
                  Moderator
                  • 4408
                  I've been reading so many bad thing about Castle controller's lately that I'm afraid to run them. They work fine on the bench, ok..my dining room table. But the real world is a different story. I've been debating on dumping them and getting some more himodels.
                  Government Moto:
                  • 785boats
                    Wet Track Racing
                    • Nov 2008
                    • 3169
                    Well at least, according to the specs, the BEC will deliver 5A all the way up to the 8s voltage rating on the HiModel ESC. I think I read somewhere that they use a voltage switcher rather than a voltage regulator. They don't have the heat problems converting the higher voltages that the regulators have.
                    Cheers.
                    Paul.
                    • domwilson
                      Moderator
                      • 4408
                      Yep. I read that too. How is their warrantee service?
                      Government Moto:
                      • 785boats
                        Wet Track Racing
                        • Nov 2008
                        • 3169
                        The good thing is I've never had to find out.
                        Out of the three I've got one of them won't start up. It's a suspect programming chip/memory. I must try a full reprogramme on all parameters & see if it comes good. I did that on one of the others that wasn't running properly & it's still running fine now.
                        But I understand that Himodel are pretty good about warranties.
                        The thing is, like I've posted somewhere before, I've only run them on 4s at about 80-100A . So I can't personally vouch for anything higher than that.
                        All the best.
                        Paul.
                        • domwilson
                          Moderator
                          • 4408
                          But at least they don't blow up on plug-in
                          It's just that programming with the TX sucks...
                          Government Moto:
