I have a Delta Force 33 that I want to make faster. It is currently running with a Nemisis 10xl 1668kv on 2-4s in parrell with a x447prop. What should I do to increase speeds higher kv motor, more volts or diffenent prop. Please help
Delta Force 33" Help
Lower the diameter and go to a higher pitch prop. Make sure to monitor temps when doing this. Change the strut angle or if your boat is running wet adjust your CG.Comment
you could try 5s with a smaller prop.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
