Gps
  • sjslhill
    • 1513
    Gps
    what's the best and smallest one out there now?
    thanks,
    Steve
  • Eggy
    • Jun 2009
    • 152
    Think the Garmin Forerunner 101 is the best to use. Small, light and got everything you need.
    • egneg
      • 4670
      I have the forerunner 201. It has a lithium-ion battery and you get 13 hours /charge. It also comes with a usb connector so you can store and graph your results.
      IMPBA 20481S D-12
      • tth
        • Apr 2008
        • 1510
        Garmin Forerunner 201.
        • ksm2001
          • Jun 2007
          • 377
          Take a look at the new add on GPS for the eagle tree if you have the V3 logger, was thinking of getting one myself. I saw Peter Z's and this thing is very small if I remember about .75" x 2" and very accurate.
          Ken
          DF-29,Phil Thomas Super Sport 45, SV27, Xzess 2 Evo, HOTR 32" Cat
          • NitroVal
            • Jun 2009
            • 423
            I have an old Garmin eTrex. Nothing fancy, not color, a little slow, but is small and works perfect for R/C. It was cheap and is rugged, I think I paid $100 from REI for it 4 years ago.
            The RTR Nightmare- Electric King of Shaves
            Now with 540s- 62mph
            New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
            • ncornacchi
              • Jul 2009
              • 251
              EagleTree eLogger with GPS expander is what we love to use...You can overlay actual tracking onto Google Earth, record RPM's, temps, power used, etc...
              • blakybob
                • 126
                Garmin Gecko. Has WAAS. Smaller and lighter than the eTrex. Got one off eBay for $40.
                Blake
                • toysRme
                  • Jul 2009
                  • 75
                  I have both the Eagletree and the forerunner 210.
                  The forerunner is water proof and the Eagletree is not, both work as good as each other.
                  If you have an eagletree Id go for the GPS expander, as you can graph the boats speed and course.
                  STUFF NITRO GO LIPO FASTELECTRICS.COM
                  OFF-SHORE-ELECTRICS.COM
                  INVENTOR OF LITHIUM CELLS:bowdow
                  • Colby
                    • Dec 2009
                    • 54
                    I'm also very interested in a GPS for my Hydro and am leaning toward the EagleTree system but am a little unclear on the pieces needed. Can someone confirm that I would need both the Eagle Tree Systems eLogger V3 w/Integrated Connectors and the Eagle Tree Systems GPS Expander V4 ... if the above is true then does the Eagle Tree Systems GPS Expander V4 plug into the boat's receiver to capture the data and then is removed and plugged into the Eagle Tree Systems eLogger V3 w/Integrated Connectors which is pluggged into a laptop for data downloading and analyizing? Any help on this is greatly appreciated.
                    Thanks
                    • ozzie-crawl
                      • Sep 2008
                      • 2865
                      they gps plugs in to the eagle tree logger. once your run or runs are finished you then plug the logger to your computer and down load data. there is also a led screen available that attaches to the logger and you get to see the data with out connecting to a pc, you can nominate what data is shown on the screen, it wont give you a full run Analiese like when linked to a computer but will give you top speed,highest temps,max amps,highest rpm,lowest voltage count that sort of thing.
                      • bwells
                        • Jan 2009
                        • 842
                        My vote is the Garmin Forerunner 101
                        • wolf IV
                          • May 2008
                          • 961
                          I have had one 101 and now oinly use 201's.. Lighter, battery life is rediculousely long and water froof, find them on ebay for cheap!! I found my last two on there.
                          http://www.youtube.com/watch?v=e-npTLBHefY
                          • bwells
                            • Jan 2009
                            • 842
                            Wolf, why did you need two?
                            • wolf IV
                              • May 2008
                              • 961
                              BECAUSE OF THIS , WATCH 4:53 I VELCRO MINE TO THE REAR OF THE OUTSIDE OF THE HULL http://www.youtube.com/watch?v=ZWh2DRhJeLs TURN UP THE VOLUME AND LISTEN TO THE GUYS RESPONSE WATCHING!! FUNNY!
