question about prather props
  • bustitup
    • Aug 2008
    • 3071
    how do these props compare to octura x and m series as far as pitch and mm
    prather
    b230
    b235
    s240
    b245
  • domwilson
    Moderator
    • 4408
    Here's a nice little chart.. http://www.rcboataholic.com/hardware/prop_chart.htm
    Government Moto:
    • kevinlew211
      • Aug 2008
      • 586
      MOST of Prather prop is 1.6" pitch, let say if you choice a Prather prop with same dia with X4xx prop then you will have more top speed and also more drag and amp draw, i have great result with Prather prop with my hydro and cat.
      • egneg
        • 4670
        Here you go ...
        http://www.offshoreelectrics.com/propeller-chart.php
        Edit: Dang ... you guys are quick!
        IMPBA 20481S D-12
        • domwilson
          Moderator
          • 4408
          Another chart... http://www.funrcboats.com/prop_chart1.htm
          Government Moto:
          • domwilson
            Moderator
            • 4408
            And a Octura chart for reference... http://www.fastelectrics.com/octuraprops.htm
            Government Moto:
            • domwilson
              Moderator
              • 4408
              Prather Props:
              Prop #|Diameter|Pitch
              215 1.60" 2.5"
              220 1.72" 2.6"
              225 1.84" 2.8"
              230 1.90" 3.0"
              235 2.00" 3.2"
              240 2.12" 3.3"
              245 2.25" 3.5"
              250 2.30" 3.6"
              255 2.40" 3.8"
              260 2.52" 3.9"
              265 2.61" 4.0"
              270 2.74" 4.2"
              Government Moto:
              • bustitup
                • Aug 2008
                • 3071
                whoa!!!!...that was some quick answers to info I need
                I just picked up 3 new S&B prathers from northernboater
                b230
                b235
                b245
                and I allready have a s240
                my 34" sprintcat with a 1527/1y on 6s2p I guess I will start with the 230 and work up
                the boat seems to be getting pretty heavy while i am laying things out
                I would like to be able to oval race at a comfortable 60mph and prop up for saw runs and hopefully hit 80
                feasable?
                thanks guys
                • egneg
                  • 4670
                  depends on the motor you are using. You can get away with bigger props on a lower KV motor with mucho torque. But ... as the KV goes up the props get smaller.
                  IMPBA 20481S D-12
                  • domwilson
                    Moderator
                    • 4408
                    b230
                    b235
                    b245
                    feasable?
                    thanks guys
                    Bustitup, I think with you...feasible, possible, "Get 'er dun!"
                    I believe you can do it.
                    Mike Martin did it with a 26" DF hull.
                    Government Moto:
                      • 8011
                      You won't get near 80 mph with the 1527/1Y. I did hit the mid-80s with the SprintCat running a 1527/1D, but had lots of ESC issues - plenty of amps with that setup!
                      I tried the p235 with the 1527/1Y and couldn't get it to work very well - but then I didn't do too much testing with it. I had better luck with the x450/3 and x457/3, although the latter is really too much prop for a boat this size - I usually run that prop on my 41" 10S cat. I'm not certain of any heat issues with the x457/3 for oval racing, but the boat was almost undriveable with it. I had to ease into the throttle coming out of turns or the cat would launch itself vertically. I did come close to 60 mph with it though. Still looking for the "perfect" prop.
