Servo mounting
  • ozzie-crawl
    • Sep 2008
    • 2865
    not really just stick the mount down,i use 5min epoxy,let it dry mix up some resin brush some over the area you want to cover with the cloth,lay the cloth down and put a bit more resin on top with the brush,just make sure the resin soaks threw but dont flood it you wont need much
    • sailr
      • Nov 2007
      • 6927
      Doesn't hold up. Been there, done that. Steven's plastic mount looks GREAT to me! epoxy a piece of plywood to the hull and screw the mount to that.
      Originally posted by domwilson
      Maybe some double sided tape?
      Mini Cat Racing USA
      www.minicatracingusa.com
      • sailr
        • Nov 2007
        • 6927
        Cool! Put it on your front page in the "NEW" section! I'll be watching for it!
        I also have some new metal servo mounts I will be listing this week.
        Mini Cat Racing USA
        • properchopper
          • 6968
          Steven's plastic mount; clean area thoroughly; " Shoe Goo" will hold it semi-permanently-won't ever break loose from servo torque, but can be twisted off with a strong wrist if need be. Looking forward to the new mount, BTW.
          • M.M.
            • May 2009
            • 264
            Thanks ozzie
            One last question, you have the 25" df copy correct? How strong is that hull? Should i lay a peice of fiberglass mat down in the hull before epoxy/glass the mount in there?
            • ozzie-crawl
              • Sep 2008
              • 2865
              the hull it self is rather strong,only problem i have had is the hatch cracking
              but it was from a big crash.if yours has the wood motor mount add some extra epoxy to it
              • M.M.
                • May 2009
                • 264
                Well it had the old wood mount in it but i cracked so i made the new alluminum one for it. The only reason why i was thinking about renforcing the spot where the servo mounts to the hull was because when i was grinding out the old epoxy i may have gone a little deep and into the fiberglass bottom of the hull.
                • M.M.
                  • May 2009
                  • 264
                  Resin is drying now
                  • NorthernBoater
                    • 811
                    I have been using the 3M double sided tape without any problems. You first have to clean the surface with alcohol and then put the tape on.
                    • teach
                      • Jun 2008
                      • 509
                      Sorry to hijack here, but I just recently got a hull with the servo epoxied down to the fiberglass hull. How in the world do I remove it?
                      • z400
                        • 1311
                        Flat blade screw driver and some patients.
                        Z
                        KBB34" Mono - Fast
                        ToySport Triton- Not as fast
                        • sailr
                          • Nov 2007
                          • 6927
                          #27
                          What is the prognosis for the patients? ;-)
                          Mini Cat Racing USA
                          • M.M.
                            • May 2009
                            • 264
                            #28
                            Well my mount is all glassed in
                            Now to mount up the servo and attach the linkage tomorrow.
                            • lomdel
                              • Nov 2008
                              • 708
                              #29
                              Please post pics MM!
                              I have a Hitec HS77B low profile servo that needs to be mounted upright. Any suggestions from you guys?
                              • z400
                                • 1311
                                #30
                                Scuff the bottom and mount it directly to the hull.
                                Or, buy a set of servo mounts from a r/c truck or car and use them.
                                I used a set from a Traxxas T-maxx that were for the throttle/brake servo.
                                Trimmed a bit off the end of the legs on the mounts, turned out perfectly.
                                Z
                                KBB34" Mono - Fast
