Servo for Mini Zonda
  • Ivan Kozyakov
    • Apr 2022
    • 82
    Hi guys!
    Please recommend a servo for Mini Zonda '27/690mm. The seller recommends a standard 6kg servo, but it is too large for this small boat . I want to use a smaller 3-4 kg servo. Will this be enough to control at a speed of +100 km/h?
  • koen
    • Mar 2020
    • 357
    use a 8kg mini servo is better for control the boat
    • fweasel
      master of some
      • Jul 2016
      • 4286
      I used a Spektrum S6230 in my Mini Zonda, which ran 92mph on 4S. It was rated for 311oz-in of torque at 6V
      Vac-U-Tug Jr (13mph)
      • Alfa Spirit
        • 2131
        I use a Standard Spektrum S100 Heavy Duty servo on my Smash Shark, lenght = 880mm.
        Standard Spektrum S100 Heavy Duty servo have metal gear and ball bearings.
        • Ivan Kozyakov
          • Apr 2022
          • 82
          Thank you. I will look for a similar size and power.
          • Ivan Kozyakov
            • Apr 2022
            • 82
            Can you recommend a specific model? These are probably HV servos and will require a separate BEC?
            • fweasel
              master of some
              • Jul 2016
              • 4286
              I ran mine off of a small Turnigy BEC because the Swordfish ESC did not have a BEC circuit built-in.
              • Ivan Kozyakov
                • Apr 2022
                • 82
                Impressive result. Do you remember which СG you had?
                I plan to accelerate mine to 120 kmh on two 2960 4100kv motors on 3s and 38mm props.
                • fweasel
                  master of some
                  • Jul 2016
                  • 4286
                  I don't remember the exact number, but I bare fit two 3300mAh 4S lipos in and didn't have much room to move them around afterwards.
