Need a strong, inexpensive servo??
  • Make-a-Wake
    FE Rules!
    • 5557
    I just ordered several of these servo's for a land application and to replace the 2075 in my Big Yellow 47". If these are anything like the specs indicate, they should be awesome for 22 bucks!! Alloy milled case, 200oz. of torque, and all metal gears!! Only thing that i can see that anyone may not like is the 0.2 speed, personally i dont think it will be a problem. I'll report back as to how they perform, but geez, at 22 bucks a pop and the specs, how can you go wrong?
    http://www.hobbyking.com/hobbyking/s...5g_0_2sec.html
  • blizard05
    • Jun 2007
    • 576
    WOW I just added one to my wish list
    America home of the free, thanks to the brave [/url]
    • keithbradley
      • 3663
      I ran one of those in my 50" mono. It seemed to handle the task ok.
      www.keithbradleyboats.com
      • Make-a-Wake
        FE Rules!
        • 5557
        Cool..............already a thumbs up review!
        • Diesel6401
          Memento Vivere
          • 4204
          Nice find! I myself have been loving the EXI servo's from hobbypartz. I have a few of them including one in my 41" mono and seems to work just fine!
          180oz @ 6 volts.
          - Diesel's Youtube
          - Diesel's Fleet
          • properchopper
            • 6968
            I recently bought four of them and they are all in use. Work well, and priced amazingly low. A little heavy for small (sub 30 inch) boats but so far very pleased. I've used the HobbyPartz D226F a lot at $14.70 but high failure rate.
            • Mattwarner
              • Aug 2011
              • 487
              are these standard size to fit one of these servo mounts?
              • Mattwarner
                • Aug 2011
                • 487
                sorry just checked the website and has the measurements on there so they fit!
                • sampit
                  • Jul 2009
                  • 447
                  just added one to my prossing HK order
                  Good find!
                  FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
                  Popeye Hydro T600 1400kv 6s1p
                  • Snowride
                    • Sep 2010
                    • 297
                    Saw those a while back but noticed many negative reviews. One important issue was it is not sealed and therefor not waterproof. Did want the cool alloy case but if it does not function all to well what is the point. Ended up with this for under $17. http://www.hobbyking.com/hobbyking/s...sec%5F52g.html. Had almost all 5 star reviews plus I found this which sold me. Look at the last page post #34 where he strips one down. The review start with EXI but did not fair so well and ends up with praise for the Turnigy. These were being tested on monster trucks which take a heck of lot more abuse compared to a boat. http://www.ultimaterc.com/forums/sho...=116488&page=4
                    FYI. These are relabeled Blue Bird servos which actually have the same model number but go for $50.
                    • Diesel6401
                      Memento Vivere
                      • 4204
                      Ill have to check out those sevos listed. I've had good luck with my exi's (knock on wood), but always looking for the more reliable equipment! Great information provided guys!
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • properchopper
                        • 6968
                        My friend Stephen got one wet and it failed. Pop them open, squirt in some Corrosion-X to prevent probs, also I smeared some silicone around the case joint as well. There's actually a version a few bucks cheaper with metal bottom & plastic top but I kaboshed one on my tunnel - the idle gear post broke out of where it inserted into the plastic top so for a few bucks more the all metal one seems bulletproof.
                        • Diesel6401
                          Memento Vivere
                          • 4204
                          If opening up the servo you could just waterproof it. I didn't even take this one fully apart. Just sprayed the board. After getting wet I just open back out and spray out with some electrically cleaner and make sure the gears are lubed. https://www.youtube.com/watch?v=Treb...e_gdata_player
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • Snowride
                            • Sep 2010
                            • 297
                            Check out the second link on my previous post. The idle gear in the Turnigy one is inserted into a metal bushing in the top cap which makes it about as strong as a full metal top.
                            Actually you can see the busing here.
                            • properchopper
                              • 6968
                              [ATTACH=CONFIG]70417[/ATTACH]
                              Yup, I see it, BUT the bushing broke out the circular depression it was pressed in to. To be fair, the biggest servo failures I had were on my tunnel, where endoes would torque the outdrive with enough leverage to do the damage.
