Blizzard rigger- servo placement
  • Basstronics
    • Jun 2008
    • 2345
    One more question for tonight. I have what I have been told is a Blizzard rigger. It has home made hardware on it (very well made).
    The previous owner had this in the water. However I cant figure out how the servo was attached and in what position. I dont see any logical fit. I dont see any glue marks or holes where anything was screwed down. Nadda... Furthermore, the push rod seal leaves very little for throw so I dont think servo tape is viable option here?
    I have a Traxxas 2075 I would like to use as this boat will be going fast (I hope). I have a heavy duty servo arm. The servo rod is higher than the servo. Also the clevis is not located in line with the servo arm.
    See pictures.
  • Basstronics
    • Jun 2008
    • 2345
    Anyone?
    Ive spent almost two hours looking for pictures. I have found one but judging from the tub size it was much wider than mine OR they were using a smaller servo. After doing some measuring I think a Traxxas 2080 servo or similar is what I need. However I am unsure if this servo has the power to move the rudder especially at speeds around 60mph?
    How much rudder throw does a rigger need?
    • m4a1usr
      Fast Electric Addict
      • 2038
      Wow. Does that bring back memories. Looks like a tail pipe view of a Blizzard from the pics. You could get by with a smaller servo if you have to. I think all of mine ran a Futaba 3003. But if you choose to stick with a 2075 theres no reason it cant be made to work. One thing glaring is you dont need all the goodies attached to the servo linkage. Get rid of the turn buckle on the rudder ARM. Yes it adds adjustablity, but you can compensate for adjustment on the opposite end. With the hardware you have mounted there doesnt need to be a lot of rudder throw. And at full speed you dont need a boat load. Maybe 20 degrees each direction? Depends on how deep the rudder is.
      On the subject of rudder linkage, if you can, go down a size. Looks like you are running a 4-40 size? Dont need that. As short as it is, you can get by with a 2-56 size or a push rod in the .062 size. If that was my build I would install a push rod with a 90 deg bend on the rudder side and at the servo side put a threaded clevis going into the servo arm. You can glue down the 2075. Wont need a mount.
      Have you settled on a power system? On 2S and a 6S 540 is the bomb and on 3S a 7S 540 is the alternative. A Neu 1506 is what I always wanted to try but decided to move up in hull sizes so that never materialized. A X632 is the ticket for that little rocket. Detounged, cupped and razor sharp makes for 60+ no problem. Mine did well with a Schulze 88WO and a Castle 120. YMMV.
      John
      Change is the one Constant
      • m4a1usr
        • 2038
        BTW I dont know who you purchased the hull from but that sure looks like my hardware I used to sell back when I made such parts. After 2008 I quit making hardware as it was no longer a labor of love and just too much time for me to commit to. But it sure has my signature or should I say Ray Fullers (I copied and changed his designs) for 4 or 5 years. After he complimented me back in 2008 on its function at a local race gathering in Seattle I decided to drop off the radar. Not for fear of infringement, but because I would never eclipse that moment. Why not end something at the top?
        John
        • Basstronics
          • Jun 2008
          • 2345
          I bought the hull/hardware from Blackcat26. He said in the add that a co-worker built the boat and made the hardware. How much of that is accurate I dont know.
          The hull as pictured is exactly how I got it. Havent done much with it in like a year or so? But Im getting her done before end of this summer.
          Im going to look into changing out that servo rod, you are correct its HUGE. I dont like the pushrod boot, there is like NO give in it. So I will go down to the 2-56 size. I believe I have some threaded clevis's. I will need a Z Bend done- I dont have a tool
          For power system Im trying to reuse a motor I had laying around and batts. I have a 3660 3000KV and 3S 2200 mah batts. Also have a 120A Turborix ESC. If that ends up not working out Im will swap the motor and batts for something else. Im hoping it will perform, just concerned I may not have enough RPMs.
          I bought an X632 from you, so I should be good on the prop
          • Jeff
            • 232
            Tower Hobbies carries an expansive collection of RC cars, RC airplanes, RC boats, model trains, sot cars, and supplies for all hobbyists.
            I try and avoid paste eaters.
            • Basstronics
              • Jun 2008
              • 2345
              Went to the local hobby shop and picked up some 2-56 pushrod, 2-56 ball swivels. Im a little nervous that with just a 90 degree bend on the end it could come apart. So I put the new pushrod seal inside the hull.
              I Removed the old pushrod seal I didnt like. The hole was wallowed out into a slot slightly. However I think my new pushrod seal will keep the water out.
              Im thinking a small Z bend and put the brass connector on the inside of the servo arm as seen in the below pics.
              Now for the servo I just glue it down with CA or Epoxy?
              • hebner
                • 647
                You should try automotive goop to glue the servo in place, it's what I use, never had one come loose.
                • Basstronics
                  • Jun 2008
                  • 2345
                  Thanks I will get some today and get her glued down. I assume its somewhat removable?
                  Someone had a servo in here before but whatever was used to hold it down came off clean!
                  • hebner
                    • 647
                    Yes, you can remove goop, just have to pry under servo to break it loose from the goop. Then you can peel it up like taking off two sided tape.
                    • Basstronics
                      • Jun 2008
                      • 2345
                      Anyone got any pictures of one of these riggers with gear installed?
                      The water jacket I got has opposing entrance/exit for the water so I know that wont work.
                      Trying to figure out where the ESC should go (I assume the nose?) And how the wires should be run.
                      • Basstronics
                        • Jun 2008
                        • 2345
                        How about a motor recommendation?
                        I would like to get a Leopard or a rebranded leopard.
                        3650 size. Battery packs are open. I was originally thinking 3S but 2S has also been mentioned. Having trouble finding a good 2S motor.
                        2S = 5000 - 5400 KV
                        3S = 3300 - 3900 KV
                        Im just not finding anything in the 2S range. So Im thinking of buying and planning for 3S.
                        • Jeff
                          • 232
                          Hey Bass, it depends. Most racing set ups are hotter than that on 2s but for sport running you are going to have to just predict a set up.
                          The CG should be at the turnfin in my opion.
                          • Basstronics
                            • Jun 2008
                            • 2345
                            Damn the 2S is seriously hotter? I thought I was going on the high side there!
                            What RPM range would you suggest for this rigger and prop?
                            John said hes run that prop well over 40K RPM. So maybe Im shooting to low? I am just fun running- so I want a reliable setup that wont be blowing motors or esc's.
                            • m4a1usr
                              • 2038
                              2S = 5000 - 5400 KV
                              3S = 3300 - 3900 KV
                              The Leopard LBP3650/5400 2.5D would be great for 2S at 39k rpms. For 3S the LBP3650/3900 would be fine at 43k. I followed the crowd when I had my Blizzard starting out with the Hacker/Feigao 540S can. Then settled on the Lehner Basic 5300 can. With the Lehner I got by on a Schulze 88WO.. With all of the other motors I needed a CC120. Chances are with the 4 pole Leopards you could take a Octura 535 and see where you top out at but the 632 has been proven over time to perform in that hull.
                              I just used shoe goo to plant the servo in mine. Like Hebner said it will come right out when or if you want to sell or change things about. I got a picture lurking of someones "Wide Body" Blizard. 4" body. I'll find it and post. Might be an old picture of Danny's? BackEmf?
                              John
