receiver issue ? or servo
  • creekrunner
    • Dec 2017
    • 51
    One of my builds has spun out and flipped twice on me ....while going straight .....Spektrum SR210 receiver. I have other builds that use the same type SR210's and have had no issues. I beginning to think that this one receiver is having an intermittent problem.....or possibly a servo issue.. always happens about the same range away. Opinions and suggestions ?
    Thanks.......
    We need far more detail to help you. Your request is like saying “how long is a piece of string”. Give us the details of your boat - hull, hardware, motor, voltage, strut setting, prop, servo, external receiver battery, etc. A pic of the tramsom would help. We can’t help you if you/keep us in the dark.
    • creekrunner
      • Dec 2017
      • 51
      1st....thanks for your reply......I should have phrased my question differently, as I don't think a biography of this build is needed. I am just asking what has been found the be the most common culprit for a steering glitch.....receiver or servo. It's one or the other. Either is an inexpensive replacement. Receiver is a Spektrum SR210, Servo is a DS3218MG.
      Thanks
      • NativePaul
        Greased Weasel
        • 2761
        Fluid is right, from what you have said it could just as easily be a handling problem unconnected to your RX or Servo, like prop walk or torque roll.
        While I don't think it is the most likely cause, of the 2 options you have given I think the RX is more likely, in my experience when a servo goes it is gone and wont start working again without opening it up and fixing the issue.
        • creekrunner
          • Dec 2017
          • 51
          Thanks....my thoughts also........as this incident has occurred in the same location on the lake (twice) ....I have "bound" to two different radios (DX2's) yielding the same results. I'll put in a new SR215 and see what happens next spring.
          Cheers
