Corrosion X and receivers
  • JohnZ
    • May 2010
    • 254
    How much Corrosion X should I use on a receiver? Do I soak it especially the servo sockets or a light mist coat followed by a medium heavy coat?
    At that point can I install it back in the boat without any further protection?
  • fweasel
    master of some
    • Jul 2016
    • 4286
    I use it if my receivers get dunked, mainly to coat the servo contacts. A liberal spray and a blot off the excess. My normal routine on a new receiver is to disassemble and coat the circuit board in epoxy or liquid tape.
    Vac-U-Tug Jr (13mph)
    • Tamelesstgr
      • Jun 2014
      • 1516
      I put the spray tip in by the board contacts and slowly fill it until it bubbles out the top, it will work it's way in there and then I clean off the remainder.
      Great watch:
      NEVER SATISFIED RACING
      Fine Design 32 V-Hull 4082+6s
        Epoxy coating is the way to go by far. You never need to recoat it or worry about it.
        • Bp9145
          • Jan 2016
          • 1466
          Travis what brand of epoxy do you use? I'm only asking if one brand is better than another. .thanks
