Anyone use Futaba Telemetry?
  • Jamey
    • Apr 2015
    • 199
    Thinking of trying the voltage sensor for a larger sport build I am finishing up. I time my smaller boat and that seems to work just fine but this one has a lot more mah and a different running style so it would be nice to keep an eye on the voltage if it works the way it should. Curious if anyone has anything good or bad to say about it.
    Thanks!
    James
  • dmitry100
    • Mar 2015
    • 1264
    I do use it... it's a great little sensor. Except one little downside to it-- the transmitter doesn't update to the most recent voltage if your boat is too far out in the water. Make sure to bring the boat in like 50 feet away from you or so to have the most accurate readings.
    • Jamey
      • Apr 2015
      • 199
      Thanks I was thinking that might possibly be the case. That wouldn't be an issue for this purpose. Sure beats bring it all the way to shore and pulling the hatch to connect a checker. Even if I stopped a couple seconds next to the bank it would still be worth it.
      • dmitry100
        • Mar 2015
        • 1264
        Another thing you could do is add a Lipo Voltage Alarm -- you can buy one pretty cheap at Hobbyking or Ebay... http://www.ebay.com/itm/like/2015376...&ul_noapp=true
        You can make it so that the alarm goes off at whatever voltage you want... It's pretty loud too. Try that as well as a secondary measure perhaps.
        • oscarel
          • Dec 2009
          • 2127
          There are audible alarms on the radio too, just have to be close enough for the data to be transmitted.
          • Jamey
            • Apr 2015
            • 199
            Does telemetry just use a wi-fi type link? I noticed on the transmitter it does show the signal strength.
            Looks like Castle has a "Telemetry Link" that feeds esc data into the S.BUS2 instead of having to use separate sensors for everything. Pretty cool! I wonder if SF is working on anything similar?
            • oscarel
              • Dec 2009
              • 2127
              http://www.castlecreations.com/produ...ink-sbus2.html
              Thats a good find! Unfortunately the only ground radio that show's promise is the 4px. I sent an email to Futaba to see when it might be available.
              • Jamey
                • Apr 2015
                • 199
                You mean the software update? Tower shows to have the castle telemetry link in stock already. Crazy.
                • oscarel
                  • Dec 2009
                  • 2127
                  Check here, shows pending software update for the 4px.
                  • Jamey
                    • Apr 2015
                    • 199
                    Yeah I know that is why I asked if you were referring to the software update : )
                    Have you already done the V1.3 update dated 2/10? The notes don't say anything about the Castle link so I'm sure that isn't the one you would need.
                    • oscarel
                      • Dec 2009
                      • 2127
                      No, have not updated to 1.3. This is the response I got back from Futaba
                      "Futaba does not announce any new products or software until right before they
                      are available to the public. As such we have no information on this."
                      • Jamey
                        • Apr 2015
                        • 199
                        Wow that was fast but with a generic response like that it doesn't take a lot of time to research.
                        Looks like only one futaba radio works with the link right now. Wouldn't expect castle to sell to many until futaba can get these updates out there.
                        • dmitry100
                          • Mar 2015
                          • 1264
                          Why is it always the stick radios that have the best range/telemetry support compared to pistol ones?
                          I wouldn't really waste my time with these types of proprietary telemetry systems when theres things like this out there: http://www.sm-modellbau.de/shop/
                          They support just about everything especially (Multiplex M-LINK) LIVE feed telemetry-- Jeti Duplex (auch EX), Multiplex M-Link, Graupner HoTT, Robbe/Futaba FASStest S.BUS2, JR Propo DMSS und FrSky
                          • Jamey
                            • Apr 2015
                            • 199
                            Messed around a little this weekend with the 4pls. I monitored the telemetry signal strength a couple times and it seemed very good. I don't know guys but it showed good signal strength well over 50ft. I would say more like 50yrds out and the signal showed fine. Maybe in actual use with a sensor it doesn't actually pan out that way? I will say it is next to impossible for me to look at the screen and drive so I would have to probably let the boat come to a stop before I can even figure out what I am looking at.
                            • oscarel
                              • Dec 2009
                              • 2127
                              That's cool, but the only Futaba that would be supported are the high dollar stick radios that support FASStest.
