Throttle Calibration on ESC With Pistol Grip FM Radio
  • 10gauge
    • Aug 2007
    • 281
    Guys, I can't seem to calibrate my ESCs as I have several Turnigy, Avionics Captain 45, and Castles. When I plug in an ESC to a fully charged LiPo, I get the beep. But, I can't get into calibration/programming mode with any of them. The steering servo works, but throttle doesn't. I've tried it with several receivers too - same thing. My radio is a Hitec FM Aggressor. It's been a while since I last ran a boat.
    Any ideas on what it could be and what I should do with the Hitec FM radio?... Should I adjust throttle response?
    Mean Machine Cat: 9XL, 4S2P, CC120, M545 (50mph) -- DF22 Hydro: 8L, 3S1P/4500, CC120, x637 (49mph) -- M-1 SuperCat: 1521/1Y, 6S2P, CC240, x447 (61mph) -- SV27 Mono: stock setup, 14-cell/4200, x642 (42mph) -- Micro Scat Cat: 28-3600, 3S1P/2100, Turnigy 60, x430 (41mph)
  • ray schrauwen
    • 9472
    If you are using BEC in the esc's, try not using it by removing the red wire from the connector and use a separate RX battery. Sometimes the Bec can't power up the rx fast enough to get into calibration mode. Check if throttle channel 2 is normal or reversed too.
    • 10gauge
      • Aug 2007
      • 281
      Many thanks, Ray! Excellent advice! I'll follow these steps.
