Spektrum range issue?
  • Andris Golts
    • Jan 2011
    • 504
    Hi all a while back boating at the lake i fully charged my DX3S TX and noticed after the boat travelling about 400' the failsafe kicked in the rx in the boat is the SR33OOT,. Has anyone had range issue's with the DX3S system? Regards Andris Golts.
  • jcald2000
    • May 2008
    • 774
    They are Infamous for having range issues on water. They make a Marine receiver which helps.
      My DX3R-PRO with MR-3000 receiver has 'unlimited' range - well, at least out to 300 meters which is as far as I have tested it actually running on the water. I run the short antenna 5" outside the hull with the other at 90 degrees to it inside (RTFM), and adequate receiver voltage is important for functionality. BTW the boat is awfully small at that distance.....
      • Darin Jordan
        • 8335
        The older SR-series RXs don't give good range over water. The newer SR-410, SR-4210, and other DMXR RX provide a better range, as far as Surface RX's go.
        The MR-series (MR3000, MR200) are what you really want to be running.
        Darin E. Jordan - Renton, WA
        • runzwithsizorz
          • Jan 2009
          • 896
          I have used this same TX/RX with the antenna inside a *fiberglass* boat and have had no range issues. Though I rarely go as far as you, lol, kinda like having ground level seats at Watkins Glen.
          • Darin Jordan
            • 8335
            I used to run an SR3100 in my ELAM and NEVER had a range issue, but then, I only raced on official race courses with it. Trying to drive it out to 400 feet+ wasn't in the plan.
            • olwarbirds
              Magic Smoke Wizard
              • Oct 2012
              • 1136
              For the first time ever ! I had a boat I setup for one of the newbie vets that had range issues. DX3E & SR301, in a abs hydro hull. I've been running Spek eqpmnt since they came out with the first DX6I and have Never had range issues. I think this one is a prob with a xmttrs range. I will just send it back to Horizon and as always with them it wont be any kind of an Issue, some the best CS in the hobby world far as big dealers go.... DJ
              • Andris Golts
                • Jan 2011
                • 504
                Thanks to all for all the information i will be mailing the tx and all the 3 rx's im having issues with including the MR-200 WHICH IS GLITCHING. Regards Andris Golts.
                • olwarbirds
                  Magic Smoke Wizard
                  • Oct 2012
                  • 1136
                  By chance, are you running a castle esc with a savox servo, or just a savox or digital servo, if so you might cure your glitch problem by just adding a simple item called a glitch buster. I got 2 of them off ebay for 5$ shipped.....
