Skip the flysky stuff. Bad news when they malfunction.
What's the best long distance radio??
I've run Fasst for years, very reliable. I run stick radios so I started running an 8J FHSS system last year. Either system works great. I've never had one come unbound (except for one very wet receiver), even in my very small carbon SAW boats at pretty good distances.
My .02
YMMVBrian "Snowman" Buaas
Team Castle Creations
NAMBA FE ChairmanComment
Most any 2.4 system will have extreemly short antenna length, keep in mind that altitude is a major factor in extreem radio range. (I don't think you REALLY want 6,000 feet range) if you do, stand on a hill or a ladder for maximum range.
Having said that, I personaly mount my Futaba reciever with the antenna inside the fiberglass hull, up high near the top of the transom.
I get super range with that setup, at about 1/3 of a mile away ( around 2,000 feet away)
I can barely see my model (radio range exceeds your vision) and the sound is delayed due to the distance, it has a wierd effect on your senses...60" Expresscraft SuperCat
(2) 2028 Castle motors 64.7 mph
10s3p with x450/3 props 15,000 mah 40c cells,Comment
I bought this one. Seems to be very good. Have always had good luck with Futaba.
Futaba 4PL 4-Channel 2.4GHz S-FHSS Radio SystemKartRacer ~ Dennis B
Delta Force Pirate 35'~Leopard 4092~1480Kv~Seaking 180~2X6S 65C 5000 Mha Dynogy Lipo,ParallelComment
If you are running a modern Spektrum system, using the MR-series RX's, and you are "regularly losing signal", you are doing something wrong, or have the worst luck on the planet...Darin E. Jordan - Renton, WA
fasst60" Expresscraft SuperCat
try these one they seem to never lose signal if you have the RX in a ballon http://www.hobbyking.com/hobbyking/s...io_System.html ,these radios have all the digital screens and buttons like the spektrum and futaba and they also have a real good rangeComment
