i picked one up from hobbypartz but there are no instructions included. i think there was also supposed to be a cd rom? i tried downloading the manual but its not working for me. i dont run windows, so not sure if thats why…. if anyone has spare instructions or can quickly guide me thru how these work id appreciate it. Thanks =)
FLYSKY GT3B --- help please
I am not too good with computers but I do have a PDF on my computer. I can print it and send it to you but you don't want to wait that long or email to you as an attachment? BTW, it is confusing and I still forget how to every time I have to program a new RX. It is your call, I just want you to get it ASAP.Too many boats, not enough time... -
I was able to find a manual online, but it reads like a chinaman speaking English hehe. I haven't tried using it yet but, I was curious about settings like mentioned (reverse throttle). On my tactics, the throttle must be on reverse with the trim cranked. I'm wondering if these radios have any tricks I need to know to function properly. Also, must the antenna come out of hull? To bind receiver, must I use a bec pack? Do I hook up esc to acc to bind? Or channel two to get power?Comment
look on hobbypartz website on the page where you buy it. There is a video and he shows how to do everything. That's how I did mine.The Speeders*PB SW 26 BL *PB Formula FASTech
The Cruiser*CBM Marlin Cruiser
The Pool Toys*Proboat Mini-C (x2)
If you look on YouTube, there are many vids on how to operate and pair this radio system. My radio did not come with the cd so I just looked on YouTube!!! Works great!Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!Comment
same here. You tube is also where i figured out where to bind it Hobby parts has bind instructions on their site as well. The big knob controls most the stuff, then you select what ever is highlighted with the menu button. Push the knob down to enter the menu screen and then rotate it to move around.Comment
Sorry did not read your post properly. Bind the receiver with esc plugged in acc. Once binded turn off and servo to channel 1 and esc to channel 2 keep in mind positive and negative must be in the right place (black and red ) is marked on the receiver in small writing. Don't bother with the arial leave it in the boat away from metal objects.Comment
Mine didn't come with CD Rom either. Although I read the instruction with much guess work. Basically is like this : insert binding plug into ch.3/bind port, power your RX with receiver pack---- plug the lead into VCC port, you should see LED flashing, you are in binding mode. Press the "bind " button ---uppermost button on the righthand side of transmitter while turning on the transmitter. Led indicator should stop flashing, might take 5 seconds. Release "bind'' button, unplug the binding plug from RX, you should be in business.
I have not used this radio on my boats yet, so far it works great on all my land RC's
Can't tell you about throttle trim and channel settings with marine ESC, sorry.Too many boats, not enough time...Comment
The intructions are hopeless. I'm no expert on these but they are very good value. I run three boats of this one transmitter. Ive have personally taken it 300 meters away and no problems ( only you can't see much of the boat ). They basically set all of the receivers to 1 frequency only which is dictated by the transmitter, no 2 are alike apperently. They only hold the trim and throttle settings ect. in memory as you store them on model no. Hope this makes sense I'm no good expressing my self on these computers. Basically you can drive any boat on saved model no.s because they are using the same frequency but the difference is it keeps your fine tuning for trims memorised. Hope this makes senseonly only trying to help.Comment
KenComment
