ive used the mr3000 in several boats but have never used the mr200. Do they work as well? They are a lot less expensive and i don't need the third channel
spektrum rm200?
spektrum rm200?
white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1Tags: None -
I use them all the time. I have more of them then the mr3000 (cost reasons like you mentioned), they work just the same.. AWESOME! -
Sweet! What I wanted to hear from some one I trust. Thankswhite geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1Comment
I use the MR200's all the time... both ESCs are equally fantastic!Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby."Comment
what's a good reasonable radio that I can run several models on?white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1Comment
what's a reasonable radio that will run several of the spektrum Mr receivers and easy to program? What are you using diesel?white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1Comment
That's the two I was looking at. I think the c is all I need and for the money a good deal. Thanks guys.white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1Comment
Diesel on the Spektrum radios do you bind any amount of rx to the 1 tx even if the tx dosnt have a memory facility or does the memory recognise each rx. As ive been told by some model stores that if the tx dosnt have a memory facility you should bind each rx each time you use a different model. Martin.Comment
Sent from my T-Mobile G2 using TapatalkComment
Yes that makes sense,Its just that in the UK we have some cheapish Chinese radios as does everywhere else that have no memory but a lot bind multiple rx to 1 tx & they all seem to work ok without rebinding when they change to a diff model,Ive done this myself but have been told by a number of sources you shoulnt do it this way. Having had a boat lose steering & hit the bank & 50-60mph im now getting a radio with memory which will be a Spectrum. Martin.Comment
