Throttle is on if radio turns off
  • Mtwinste
    • Jul 2011
    • 135
    If I turn off my radio the throttle instantly goes about 30%. How to fix?
  • JimClark
    • 5907
    turn your radio off last when you are done
    Billy Graham
    • Mtwinste
      • Jul 2011
      • 135
      What if I run outside of range or controller batteries get weak. The same thing will happen and runaway boat.
      • carlcisneros
        • Jan 2010
        • 1218
        If your radio is set up with failsafe, (we do not know what radio you are using), please us that feature and set the failsafe to go to
        OFF throttle if the range goes too far or the transmitter is turned off first.
        you should always turn off the transmitter LAST.
        • Mtwinste
          • Jul 2011
          • 135
          Spektrum DX3S and MR2000 receiver.
          • Mtwinste
            • Jul 2011
            • 135
            I don't see a fail safe mode on DX3S
            • carlcisneros
              • Jan 2010
              • 1218
              I am sure that someone with the spektrum radios will chime in.
              I use NOMADIO and Flysky GT3B radios.
              both have fail safe features.
              • JimClark
                • 5907
                read page 17 of your manual
                Billy Graham
                • Shooter
                  Team Mojo
                  • Jun 2009
                  • 2558
                  What ESC are you using
                  • Mtwinste
                    • Jul 2011
                    • 135
                    Page 17 of instructions sorry duh
                    • Darin Jordan
                      • 8335
                      You need to rebind the RX to the TX... The failsafes are set when you bind. Sounds like you may have had throttle trim or throttle on when you bound it??
                      Darin E. Jordan - Renton, WA
                      • BBQSteve
                        • Jul 2011
                        • 36
                        Mine does something similar with radio on. Throttle goes to 25% and no radio when battery is supposedly low, however when I retrieve it, turn radio switch off then on it regains radio and motor quits running. This has to be in the ESC (ProBoat waterproof ESC with reverse PRB2314).
                        BBQ Steve
