Spektrum DX3 interference?
  • ScarabChris
    • Oct 2010
    • 752
    This has happened a few times. Running the boat and all of a sudden the thing takes a hard turn.
    I thought a bad servo so I changed that. Then I thought a bad RX so I changed that. It still happens from time to time. Like tonight in my house I am reprogramming the ESC and all of a sudden the outboards are turning left and right with no input from the TX.
    Any ideas?
    - When was the last time you bound the transmitter and receiver together?
    - What throttle and rudder positions did you program as the failsafe?
    - Receiver and transmitter packs fully charged?
    - What hull - any carbon fiber in it?
    - How is the receiver antenna positioned and how far out of the hull?
    • JimClark
      • 5907
      Ya what Jay said
      Billy Graham
      • AndyKunz
        • Sep 2008
        • 1437
        What receiver are you using?
        Andy
        Spektrum Development Team
        • ScarabChris
          • Oct 2010
          • 752
          I just rebound them last week when I switched the RX.
          All neutral on the failsafes.
          Batteries fully charged.
          No CF in the hull.
          Its the SR300 RX with the small antenna, it doesn't exit the hull at all. Keep in mind this was happening on the bench with the TX six inches from the boat.
          • dana
            Banned
            • Mar 2010
            • 3573
            have you waterproofed the rx with anything?
            • ScarabChris
              • Oct 2010
              • 752
              Nope.
              I just tested the boat and its working fine. The boat must be haunted because I have this interference and the ESC problem at once.
              • dana
                Banned
                • Mar 2010
                • 3573
                try another radio system
                • Darin Jordan
                  • 8335
                  It's not the TX, it's the RX... Thats a car RX, and was never really meant to be used in a boat. You really want the MR200 or MR3000 RX for this application.
                  Darin E. Jordan - Renton, WA
                  • NativePaul
                    Greased Weasel
                    • 2760
                    Why should being a car RX matter if its inches away from the TX on the bench, which is I guess on land? If 2 different RX are doing the same thing on the bench it sounds like a TX problem to me, but what do I know, I don't even run spectrum.
                    • AndyKunz
                      • Sep 2008
                      • 1437
                      It could also be a power supply problem in the boat.
                      Darin's right about the receiver. When you have the boat on the water, you should be running an MR-series receiver (make sure your DX3S has a picture of a boat on it, though. Early DX3S's were not Marine compatible and didn't have the boat picture).
                      Verify that you have good voltage getting to the receiver. Carefully measure it! You don't want to short anything out. I have a servo lead that I removed from a dead servo with the leads trimmed to different lengths. I can just clip my voltmeter to it and they won't short out.
                      If you have good voltage on the receiver, good voltage in the transmitter (above 4.5V), and it's doing this on the bench, you need to call our Customer Support line. It will probably have to come back here.
                      Is this in that boat in your avatar? Sure looks like fun!
                      Andy
                      • ScarabChris
                        • Oct 2010
                        • 752
                        OK here's the scoop. Yes the boat is the one in my avatar. Do a search on my username or "scale scarab sport" to see build pics.
                        I got the radio system from Steve here at OSE. The original was the Spektrum DX3E with the SR300 RX. I was having the issue with this setup.
                        Then for my new build I purchased the Spektrum DX3S also from OSE. This unit allows me to use it for more than one boat. It also came with two RX. One was the SR300 and one was the SR3300T.
                        I installed the new SR300 in this boat and am now using the new TX with this boat and will also use it with the new boat using the SR3300T once that build is completed.
                        I am having the same interference issues even with the entire new radio system.
                        And again this was happening even with the boat on the bench in my shop with the TX 6 inches from the boat. But I was also able to run the boat today for a short time with no problems but it did occur again once I was running for a few minutes. In fact it was so bad the boat was running at full speed and out of nowhere it hooked hard and I almost stuffed the boat.
                        There is no rhyme or reason to the interference. It comes and goes at will and is very unpredictable. And it didn't always have the issue, it just started a couple of weeks ago. I'm not sure its a radio problem but something in the boat causing the problem. I just can't figure out what it is.
                        • BHChieftain
                          Fast Electric Addict
                          • 1969
                          Have you tried using one of the spektrum's marine receivers? They are specifically designed for water applications (ie, two attenneas, plus water resistant casing).
                          Chief
                          • AndyKunz
                            • Sep 2008
                            • 1437
                            6" away is a problem. Try 6' away. When you are that close, you are hammering the receiver way too hard.
                            What was the result of your voltage measurement test?
                            Do you have only one BEC enabled?
                            When you get to the point where you're ready to run the boat, BE SURE you have the right receiver in in (MR-series, not SR!).
                            Have you tested the steering servo(s)? Try connecting a good servo instead, and power it with a single BEC/battery. What happens now?
                            Andy
                            • CornelP
                              • May 2009
                              • 745
                              I had a similar problem last week with my boat. Tx is a Dx5, with AR500 Rx or the cheap Orange DSM2 compatible Rx (which, by the way, is very good even on water) . The ESC was a Turnigy 180.
                              After doing some testing, I got rid of the glitch by using a battery pack instead of the internal BEC. I was running only on 4S, so it was supposed to be ok...
