What is considered the best methods of sealing the esc & 2.4ghz receivers. Coating in electronic grade epoxy, Setting in a thicker epoxy block or useing Corrossion X or any other methods. Thanks.
Sealing esc & reciever
A lot of guys use corrosion x, I use this stuff though. I use about 5 coats, just make sure you cover the connection tabs on the rx where the servo, esc ext plug in. I place a piece of foam over them. Works for me and saved a few rx's. -
I wrap my recievers in silicone self fusing tape and use a little silicone where the wires come out it works awesome and you can take it off without leaving anything behind.
it will work like putting stuff into a balloon but the self fusing tape wraps it perfectly to the objects shape and because it's silicone it wont rot away like arubber ballone and it will last for ever!Comment
A lot of guys use corrosion x, I use this stuff though. I use about 5 coats, just make sure you cover the connection tabs on the rx where the servo, esc ext plug in. I place a piece of foam over them. Works for me and saved a few rx's.Comment
If useing say Corrossion X i assume you give several coats allowing to dry in between coats, Does it need further coats added after a certain time. Also if the esc or rx gets wet do you dry out then add another coat or apply as soon as the esc or rx gets wet. I assume you can also use Corrossion X inside servo electrics.
I never reapplied it I guess if your boat sank under you can reapply it won't harm anything.Comment
