Attention 2.4Ghz Radio Users
  • Darin Jordan
    • 8335
    It was brought to my attention today that there are some servos from Hitec, and possibly others, that don't "play" well with the low voltage, 3.2V, output signal of the new 2.4Ghz systems.
    Spektrum sells an inline comparator that boosts the signal voltage. Part number is SPMCP, and can be found on the Horizon Hobby site, here:
    Thanks to Doug Smock for reporting the "issue" and bringing the solution to my attention.
    Darin E. Jordan - Renton, WA
  • Jeff
    • 232
    Looks like a "patch " cable to me.
    Jeff
    I try and avoid paste eaters.
    • Flying Scotsman
      Fast Electric Adict!
      • Jun 2007
      • 5190
      Am I missing something here, if you disable the bec circuitry and use a seperate power source, would this not solve the problem.
      Douggie
      • egneg
        • 4670
        It looks to me like folks are being charged a fee to remedy an engineering screw up.
        IMPBA 20481S D-12
        • alvinsmith75
          • Jul 2008
          • 635
          I thought the esc's bec determined the voltage output?
          • Doug Smock
            Moderator
            • 5272
            Douggie
            No sir.
            Doug
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • AndyKunz
              • Sep 2008
              • 1437
              The POWER comes from the BEC. This is typically about 5V. The SIGNAL comes from the receiver. On the Spektrum (and many other modern rx's) this is about 3.2V. Modern servos don't have a problem with this, but older ones will because they're expecting the SIGNAL to be pretty close (75% or higher) of the POWER voltage.
              I take it that you got the e-mail from John, Doug? I asked him to send it direct but had a CDL physical this afternoon and haven't checked back.
              Andy
              Spektrum Development Team
              • sailr
                • Nov 2007
                • 6927
                Is this just for Spektrum radios that have the problem or.....?
                Mini Cat Racing USA
                www.minicatracingusa.com
                • Doug Smock
                  Moderator
                  • 5272
                  Andy
                  Yes sir I did. Thanks again for taking the time to get me (us) an answer.
                  You da man!!!
                  Doug
                  BTW fellas, I was only having trouble with Hitec HS 645 and 985MGs. These MR200s have been flawless in my P- Limited setups with HS 225MGs.
                  Another note: My MR3000s don't have a issue with either of the above servos.
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
