Ok gang,
Im ready to hit the water today if I can get this ESC figured out.
Heres the ESC and the radio:
My last radio was a Team Associated XPS
here was the procedure for it:
With the new radio I have tried it with the throttle reversed, forward, neutral, advanced and retarded. All the same result. It will arm but as soon as I let off "full reverse/stop" and let the trigger to its neutral (no force on trigger) it begins to run.
Im a little peeved right now. After a year long break I was hoping to get this into the water!
HELP! Please!
Throttle Advance HI -> max setting
Throttle Advance LO -> low setting
Throttle Trim-> low setting
Turn tx on. Turn boat on. Motor starts the fast paced di-di-di noise. Pull trigger for max throttle. Motor makes chime like noise, then 3 beeps. After third beep quickly move throttle to opposite position. Motor makes one beep. HOLD THIS POSITION. Motor makes music noise. Then one beep.
HELP! Please!
