cooling jacket for neu castle
  • bustitup
    • Aug 2008
    • 3071
    well I think its going to work......I'v got my finned Neu Castle 2200kv motor and took a kb45 cooling jacket and slid it ofer the fins.....experimented with some diferant size o-rings and getting ready to seal it up......first picture is with the o-ring installed...second pic is the gap you see before I add the new o-ring...what sealnt should I use for this
  • calcagno45
    • Mar 2008
    • 1006
    O-rings should seal up the void. I've never used a sealant on any jacket. Just lubed the rings before sliding on and let it ride out after that.
    • Mel279
      • Dec 2008
      • 857
      Good modification
      Check for water leak first before your run it
      • bustitup
        • Aug 2008
        • 3071
        I would agree if this was a normal situation but due to the fact that this is a finned motor and the water jacket was made for another motor things are a little different...when I put both o-rings in ......the slightest bump makes it all fall apart but it does seal good while its together..you can blow air in one inlet and put your finger over the outlet and it holds air real good...its going to need silicone.........would just regular clear silicone work?...would it take the heat of the running condition of the motor?
        • calcagno45
          • Mar 2008
          • 1006
          Silicone should work, if possible use High Temp just to be safe.
          I would pressure test it first tho, try to push some water through it.
          http://www.offshoreelectrics.com/inf...tem-tester.php
          • bustitup
            • Aug 2008
            • 3071
            aaaah yes thats the ticket "high temp" silicone...and yes that tester is a good idea...thanks
            • calcagno45
              • Mar 2008
              • 1006
              I used the same tester idea. I made a piece to slip inside a garden hose and reduced it down to fit my 1/8" tubing. That way I can do it outside, easily.
              • bustitup
                • Aug 2008
                • 3071
                yes I like that idea better...that way if it starts spraying water everywhere at least your outside
                • Steven Vaccaro
                  • 8724
                  Nice job!
