Lehner 3060 875kv
  • BlakeT
    • Jan 2020
    • 536
    Lehner 3060 875kv
    I have this 3060 that I am thinking of putting into a new falcon cat 41 hull. The hull is very light at 3 pounds dry and I was curious if I should run 8s with this motor on go up to 10s and swing a smaller prop the higher rpm.
  • photohoward1
    • 1610
    If you want to run 10 go with a 460 or so. I loved this motor on 8s with a large gas prop. Made the mistake of putting 10s in it with a 470 prop. was fast for a few laps and then Poof went the motor.
    • Bande1
      • Mar 2023
      • 680
      Run both. in fact try 12s also. I got a sprintcat 42 with an 850kv 5670 I swing between 8s, 10s, 12s. I use a 1715 on 12s, a prather S230 on 10s, and a 2216/3 on 8s
      • fweasel
        master of some
        • Jul 2016
        • 4287
        That motor is an 8 wind and can be run in triangle or star config... 875kV or 506kV. Pick your poison.
        Vac-U-Tug Jr (13mph)
        • BlakeT
          • Jan 2020
          • 536
          That would be interesting to try the lower kv although I have never worked with anything that low of rpm before.
          • BlakeT
            • Jan 2020
            • 536
            This motor I wouldn’t stress as much as my tp motor like you have. I actually have that same tp motor in an avenger 36 and I run x457/2 running mid 70s on 12s. Going to make a strut adjustment and try my abc 2315 on it for some more speed runs. I would definitely try that 2216 on 10s with that boat I am certain the motor can handle it hopefully your esc can.
            • BlakeT
              • Jan 2020
              • 536
              That is my biggest fear is cooking one of these motors for sure! Was yours the same wind as what I have? That’s very impressive that it swung those big props.
              • Bande1
                • Mar 2023
                • 680
                how many watts that setup pull? I got dual fans on the motor running a 1715 pulling 7kw.
                • BlakeT
                  • Jan 2020
                  • 536
                  I’m not sure about how many watts it pulled but I can run it for a decent amount of time without things heating up. I have an old flier 300 esc on it.
                  • photohoward1
                    • 1610
                    You will cook it on 12s...guaranteed. They are finicky motors. If everything is not balanced and aligned perfect it will vibrate a blow the windings. Guaranteed.
                    • BlakeT
                      • Jan 2020
                      • 536
                      I certainly won’t try it on 12s with this wind, I’m afraid to put 12s to my 10 wind already lol. Tyler Gerard had told me
                      To stick with low pitch props and usually octura so that is what I have done so far. I’m thinking of going 10s and trying a x455 octura and see how it goes.
                      • vvviivvv
                        • May 2009
                        • 1079
                        3060's are tanks,
                        you wont blow one, maybe a esc but the motor is solid. i ran a 3060 1000kv in a mono on 10s, small ish prop and was around the 85mph mark
                        I have 6 3060 motors at the moment running them in 650kv up to 1000kv configs with 12 - 14s on them depending on the boat / goal.
                        Uk SAW record holder
                        • photohoward1
                          • 1610
                          Originally posted by vvviivvv
                          3060's are tanks,
                          My collection and Bank account would disagree. :)
                          • vvviivvv
                            • May 2009
                            • 1079
                            i even have 2x 3060 1750 KV
                            • EddieM41
                              • Aug 2018
                              • 192
                              vvviivvv, I have a TP 5670 990Kv running on 10S with ZTW 300 esc. I'm running around 73mph. Is there much more in this set up without burning the house down. Currently weighing in at 13lbs totally ready to go. Batteries, motor, and esc well within temperature range.
