Converting from gas to electric
  • Jdupay
    • Sep 2023
    • 2
    I am relatively inexperienced in the world of RC boats and I am looking for advice. 5 years ago I built a wood v-hull rc boat. It is 4 feet in length 15 inches wide and weighs 15 pounds with the gas motor that is currently in it. The motor is currently a 26cc two stroke. I am looking for suggestions on what kind of motor and ESC set up I should be looking at to be able to power this boat.
  • Bande1
    • Mar 2023
    • 680
    a gas system is quite a bit less weight of an electric setup if that is your primary concern. a 26cc engine weighs about the same as medium 8s battery pack. not counting the motor and ESC which makes electric easily double the weight. Ive been converting my electric hulls back to gas, personally. its so much cheaper and more fun than waiting around for hours for large, multi-hundred dollars battery packs to cool down and then recharge.
    • fweasel
      master of some
      • Jul 2016
      • 4286
      A boat that large will work best with a single 56mm motor, lower kV , and a larger prop diameter similar to what you were running on gas. Assuming you're looking for similar performance as your gas setup, something in the 600-800kV range depending on voltage is a place to start. As for batteries, you're run time is going to be significantly less. If something in the 4-5min range is acceptable, 2x5S 5000mAh or 2x6S 5000mAh lipos in series to give you 10S or 12S respectively is a good start leaving room to move the weight around to adjust center of gravity.
      Vac-U-Tug Jr (13mph)
      • Bande1
        • Mar 2023
        • 680
        on my gas conversion with a single 56mm running 6500mah and 7600mah budget packs I get about 90-110 seconds at a 55mph pace. about 45 seconds if propped up to go over 60mph. I would highly advise bare minimum of 10,000mah for approximately 3 minutes of run time. a stock 26cc, which I own and run, is approximately equal to about 4500w or so. about 165A load on 8s.
        • fweasel
          master of some
          • Jul 2016
          • 4286
          We're talking about very different setups if you're only able to run 90seconds. On my last Zelos 48G conversion, I ran 2x6S 5000mAh packs and got about 4min when propped for 70mph top speeds, which was significantly faster than the 30cc gas setup I replaced.
          • Bande1
            • Mar 2023
            • 680
            you went 70mph for 4 minutes on 5,000mah in a 4ft long boat? that would be about 7kw at least. the calculator has that at 103 seconds. which is almost always way over blown for runtime.
            you would have to pull 75a to run 4 minutes. which is about 25mph.
            • fweasel
              master of some
              • Jul 2016
              • 4286
              The run was bashing, peak speeds were 70mph, not continuous.
              • Jdupay
                • Sep 2023
                • 2
                If that is the case, do you have any suggestions on a better gas set up? I currently have a cheap medium quality motor in it and I have never gotten it to run right.
                • Bande1
                  • Mar 2023
                  • 680
                  start with the basics. is the carb adjusted right? 2 1/18 turns out on the low needle. 1-1 1/8 out on the high needle. the carbs need to be drained after use by pinching the line and letting the engine idle until the fuel runs out. after some time the carbs need rebuild kit. easy and cheap. the tuned pipe. when you move the pipe fore and aft on the exhaust manifold it adjusts the power band RPM. generally 13.5 inches from the mufflers ridge to the manifold face.
                  next, gizmo motors sells racing mods for about $200-250. with a stroker crank, ported head, etc. it will get you into the 60mph+ range. There are people that will build the motor for you such as Huff racing. Intlwaters forum is the place to go for gas boat knowledge.
                  if you are just not a gas person then fine, go electric. get those rail mounts OSE sells and an electric motor should bolt right up to the engine mounts. You can get a budget motor like the rocket RC 56102 for $120 on amazon. a set of SMC HCL_HC (hc = high capacity) 8800mah for $160. Run 8s via two 4a packs in series with a super low KV motor like 600-700kv. that will allow you to use your gas props. you will need a charger, spend another $100 for that. The ovonic chargers on amazon are pretty nice for $100 and charge 4s packs at 12a per channel on your vehicles starting battery.
                  • Peter A
                    • Sep 2012
                    • 1486
                    Sorry Bande your math is wrong. A stock 26 zenoah is 3.5 hp or 2625W equivalent.
                    4500W on 8s is 155A - 4500/29 = 155.
                    I have a stock 26cc Thunderboat and I am giving serious thought to converting it to electric. The big advantages I have with this are that I have a spare painted hatch, motor (TP4070 440kv) esc etc. I can fit the motor in the existing gas mounts and batt trays outside the rails, so it can easily be converted back. This motor on 12s in a 45"mono turning a ABC 2314 /4 chopper prop ran at 90 kph and drew around 60A, I could do two heat races on 6000mah. With a bigger prop on the Thunder boat it would be faster than it is now and easy on batts for heat racing.
                    One of the guys in our club converted his Slingshot gas rigger to electric. It runs a TP5670 650 kv, ZTW300 G2 esc, 12s (2x6s) 5000 mah, detongued X470 at 130 kph and does heat races without cooking batts.
                    To the op, the extra weight of electrics in a mono does not effect the top speed, and it can be of advantage in rough or race water. It all depends on what you want to achieve with your boat at the end of the day.
                    • Bande1
                      • Mar 2023
                      • 680
                      Ive ran them back to back with a tp 4070 pulling 4387w on the data log went the same speed as a zenoah 26cc in the same boat. about 53mph.
                      in regards to the slingshot rigger the guys in my club developed and build that hull. Running pro mod 29.5cc they run 9 second laps. 10 second laps are 90mph sustained. Their 8hp engine, which should be equal to 6,000w, literally laps my 7000w, 12s sprintcat once a lap. Its not even in the same universe.
                      • Bande1
                        • Mar 2023
                        • 680
                        I should say not back to back ive ran electric and the 26cc, it was a month apart but nothing had changed with the hull.
                        • lohring
                          • Jun 2011
                          • 183
                          Everyone I know runs tuned pipes on their stock Zenoahs. Our testing shows a little over 4 hp with the right pipe. That's a little under 3,000 watts. On 6S that needs around 120 amps.
                          Lohring Miller
                          • Bande1
                            • Mar 2023
                            • 680
                            Lohring Miller
                            IF you believe 750w = 1hp
                            seems more like 1000w = 1hp in real life to me (maybe its the extra weight of electric)
                            • Xrayted
                              • Jan 2023
                              • 274
                              Science and facts are great like that. They dont change or become invalid based on what anyone "believes" or lacks in understanding of them
