TP 4050 disassembly question
    • 7673
    Hey guys, I’ve been slowly working on my Fast Fantasm since it hit the shore. Since it ran 4 seasons I’m thinking motor bearing replacement is a good idea. They are out and the three end bell screws are out. I don’t really want to tap the rotor to pop the end bell off. Any tips or ideas/experience out there for me?
    Thanks, Shawn
  • ray schrauwen
    • 9471
    I used a piece of 0.030" or less lexan. I make it just the right size to wrap the rotor and slip inside the gap. Now if you tap the shaft with wood the rotor will not scrape the inside. I also use the lexan to re-assemble a motor if I was forced to remove the rotor to do maintenance.
    Isn't the rear just pinned or held together with screws? I guess they put glue in there too???
    Nortavlag Bulc
      • 7673
      I got the end off with a fine flat screwdriver and light tap. But man the idea with lexan(or even paper) is brilliant. And will be used from now on.
      Thanks Ray
      • fweasel
        master of some
        • Jul 2016
        • 4286
        Yes, that lexan idea is a keeper
        Vac-U-Tug Jr (13mph)
        • ray schrauwen
          • 9471
          Paper rips but, you can use cut pieces of plastic containers to do the same. Yogurt, margarine, etc...
          Nortavlag Bulc
