TP motor thrust bearing?
  • Raydee
    • May 2007
    • 1603
    Just got a 4050 motor today and noticed that a normal 5mm thrust bearing won't work as the shaft is like 10mm about 3mm past the can before its cut down to 5mm. What solution are you guys using to be able to use a 5mm thrust bearing?
    Sent from my SM-N950U using Tapatalk
    Team Liquid Dash
  • Raydee
    • May 2007
    • 1603
    I am wondering with the pinned rear end bell if I should just skip the thrust bearing all together?
    Team Liquid Dash
      • 7673
      Look for a bigger thrust bearing. They are used in lots of things. Google is your friend. BTW the shaft should be 8mm through the motor. Makes for a nice solid motor.
        • 7673
        https://www.amazon.com/uxcell-Needle.../dp/B00DN5KYT6
        • Raydee
          • May 2007
          • 1603
          For some reason when I tried a 8mm thrust bearing on the shaft it did not fit. After measuring the bearing it was actually 6mm.
          Team Liquid Dash
          • TRUCKPULL
            • 2969
            Ray
            On my twin cat, the motor mount plate is 1/8" thick.
            I put a 11/32" hole to make sure it clears the shaft.
            Now the 5mm thrust bearing pushes on the motor plate, and all is good.
            Larry
            • T.S.Davis
              • 6220
              You can also add a plate to the face of the motor mount in a pinch. I've done that a few times. I don't always use a thrust bearing. Depends on how much weight that tail bearing has to support. Judgment call. Larry's boat? Maybe should put two bearings on each side. That thing is a violent angry monster.
              Noisy person
              • Raydee
                • May 2007
                • 1603
                I may just skip the bearing all together. It's going in a 33" Jae rigger.
                Team Liquid Dash
                • TRUCKPULL
                  • 2969
                  It is not that bad Terry, It only draws about 90 AMP's a side in Oval setup.
                  I need to point my struts down a touch.
                  My driving needs to be smother also.
                  Larry
                  • T.S.Davis
                    • 6220
                    That thing is a handful Larry. I don't know if anybody is smooth enough to drive it.
                    Noisy person
                    • T.S.Davis
                      • 6220
                      Larry, at the NATS you blazed a path through the thickest lily pads I've ever seen like they were butter. The boat's amazing sir. Nice job.
                      Noisy person
                      • donhuff
                        • Dec 2014
                        • 561
                        My driving needs to be smoother also.
                        Larry
                        SMOOTHER?????????? meaning your smooth already but would like to be smooth----er?
                        I did laugh out loud when I saw this.
                        That thing is like a top fuel dragster. Point it at the finish line BEFORE you hit the throttle.
                        I was calling for Larry when he cut a "wide straight groove" through those lily pads at the start of the heat . He didn't have it pointed at the finish line, and hit the throttle anyway. Then he was on the back side of the course before I could even say GO!
                        Yes , that thing is stoopid fast.
                        AmpDaddy
                        don huff
