motor rust
  • ezhitz
    • Aug 2009
    • 428
    motor rust
    I have a motor that has not been used for the last 6 weeks that did work fine. But now when I tried it cogs on start up.
    So I opened it up and notice rust on the stator. Can that be cleaned off and still run ok or should I scrap the motor avoiding
    a risk of blowing my esc. The motor did cog on start but would run. The boat and motor were left in the garage with the cowl on
    so I think it was from condensation.
    :canada
  • ray schrauwen
    • 9472
    Doesn't take much.
    You can try with WD40 first and maybe some corrosion block after. Is it really bad or just a few spots? Magnets can rust too.
    Nortavlag Bulc
      Clogging has nothing to do with a little surface rust. If the motor windings are damaged then he risks blowing his ESC if he keeps running the motor. I think there is more to this story than just a little condensation...
      • mappo
        • Feb 2010
        • 488
        Doesn't take much.
        Ran in salt water and drowned several motors, but I just flush with fresh water and sprayed with corrosion X worked very well.
        Do you know what the biggest problem with the world is?
        That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
