Max watts from a Castle 1415 1Y
  • ray schrauwen
    • 9472
    What have some of you guys been able to get out of this motor in a hydro on 4S for racing P-Hydro?
    What do you think it can withstand continuously for a race up to 8 laps?
    Nortavlag Bulc
    My Castle 1415/1Y (not exactly the same motor) averages 100 amps logged for 6 laps plus mill on 4S in my JAE 21. Peak amps were 125. For 7 laps it uses 2400 mAh. 12 second lap times with top speeds in the upper 70s. I'm sure that a Neu would handle a lot more than that, but how much do you need?
    • RaceMechaniX
      • Sep 2007
      • 2821
      Several of us have run that motor in Raptor P-hydro's with very consistent results. We are pushing them a little harder to 125A average and about 150A peak. Six laps plus the mill consume 2600-3000mAh.
      I would not go any more aggressive than 120A. They are very good motors for 1P hydro set-ups. Heavier hydro's will want a little more motor due to cooling.
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
      • ray schrauwen
        • 9472
        So do you think this motor is a tad small for an ML RSX310 rigger? I haven't started it yet but I think it's bigger and heavier than the Jae you guys are using, yes, no?
        I was actually talking about the Castle 1Y not the NEU.
        Nortavlag Bulc
        • RaceMechaniX
          • Sep 2007
          • 2821
          Yes, I would say you probably want the 1515 size motor for better heat capacity. There is also more room in the ML rigger.
          Tyler Garrard
          • ray schrauwen
            • 9472
            Thank you. I was going to try a new Scorpion I have first. It's capable of almost 2500 watts continuous. If it's not up to the job there are proven TP motors etc... I have a 1515 castle too.
            All 2200kv.
            Nortavlag Bulc
            • robstercraws
              • Apr 2017
              • 157
              Tyler what prop are you running in your setup?
              • raptor347
                • Jul 2007
                • 1089
                1817-17-45 abc
                Brian "Snowman" Buaas
                Team Castle Creations
                NAMBA FE Chairman
                • ray schrauwen
                  • 9472
                  Brian, do you think that this motor is too little for my ML GRX310? I'm having a hard time picking a motor for it and I would like to run 1P of whatever Mah needed.
                  Just staring the framing.
                  It's possibly heavier than a Jae 21.
                  Nortavlag Bulc
                  • raptor347
                    • Jul 2007
                    • 1089
                    I'd look at something larger. I'd run a larger motor in P hydro if I wasn't trying to use my existing raptor..
                    NAMBA FE Chairman
                    • robstercraws
                      • Apr 2017
                      • 157
                      Thanks Brian. I’ll be trying a Neu 1415 in my raptor with on of your 1817’s.
