What timing should I set?
Timing for a TP 4060 1950kv 5D
Tags: None
For "D" wind motors = 0 or 1 Degrees Timing, anything more just causes heat.
They are not like a "Y" wind .
LarryPast NAMBA- P Mono -1 Mile Race Record holder
Bump & Grind Racing Props -We Like Em Smooth & Wet -
Bump & Grind Racing Props -We Like Em Smooth & WetComment
Related question: Would an "automatic" timing setting like on a Swordfish be trustworthy or harmful on a D?Comment
I have heard that Swordfish like the automatic setting for "Y" motors, but I don't know about "D"'s (I don't run them)
The timing of a BL motor cannot be a single value, the motor wouldn't work nearly as well if the timing was static like an old skool brushed motor. With decent quality ESCs it doesn't matter if you choose "0" or "5" degrees, the ESC decides what is the best timing based on feedback from the motor as the load changes. The timing you input only defines a timing range from which the motor chooses the right timing. You may set "4" but the ESC may actually use "8" simply because that is what the motor really needs at a particular moment. You are fooling yourself if you think there is any real difference between settings "0" and "1"...
