From the looks of the information on their website:
- End Bells have more venting
- Only offered currently in 2 configurations for the 3674 X2: 2650kv and 1900kv
- X2 2650kv good for 3s (12.6V) and pulls max 120 amps ***advertised*** current version good for 22V and and pulls max 110 amps ***advertised*** (both 2.5 D-winds)
- X2 1900kv good for 6s (25.2V) and pulls max 85 amps ***advertised*** current version good for 31V and and pulls max 78 amps ***advertised*** (both 3.5 D-winds)
NEVER SATISFIED RACING Fine Design 32 V-Hull 4082+6s
- both 2650kv & 2.5 D-winds
- X2 good for 3s (12.6V) and pulls max 120 amps as advertised = 1500 Max Watts
- Current version good for 22V and pulls max 110 amps as advertised= 2400 Max Watts
-both 1900kv 3.5 D-winds
- X2 good for 6s (25.2V) and pulls max 85 amps as advertised = 2150 Max Watts
- Current version good for 31V and pulls max 78 amps as advertised = 2400 Max Watts
Something fishy here - A new product called X2, You think would be 2 Times Better NOT less Max Watts.
Larry
Just from the specs the X2s look better to me, on the 2650kv 120A beats 110A, the watts are irrelevant as 2650KV is inappropriate for 6s even if the motor is capable. The same is true for the 1900KV versions, I sure as hell wouldn't be running one on 31v for near 60,000rpm so more power at a more suitable voltage sounds like a much better prospect.
Lets take the 2650kv Motor
The X2 say's it is only good for a MAX of 3S -12.6V at 120A = 1500 Watts max. (2.01 horsepower)
Current version good for 22V at 110 A = 2400 Max Watts (3.22 horsepower)
So you could run this on 4S pulling 143A and still be at the 2400W max. (3.22 horsepower)
So tell me why I would want to buy the X2 motor that only has a 3S max. with Less Max Watts??
Or even in the same 3S -12.6V setup, I can now run a larger or higher Pitch prop at 190A = 2400W (3.22 horsepower)
Lets take the 1900kv Motor
The X2 good for 6s - 25.2V at 85 amps as advertised = 2150 Max Watts (2.88 horsepower)
Current version good for up to 31V at 78 A = 2400 Max Watts (3.22 horsepower)
So if I run it on 6S-25.2V at 95A =2400Watts (3.22 horsepower)
So I think the current motor even in the same setup would be a better bet, seeing that you are not abusing it as much with a 2400W Max.
To my knowledge, that's not how electrons work. A particular material can only handle so much amperage at a give voltage. You can't just up the current "prediction" because you have a lower voltage. In fact, electrons flow easier at higher voltages than they do at lower voltages which further backs up my counter "argument" if you want to call it that. If I am correct, your entire statement is invalid.
