T.P. motor
  • urbs00007
    • Jun 2011
    • 826
    T.P. motor
    converting a nitro rigger to electric for sport running. its 42 " overall and with a 90 nitro motor and 1667 prop it ran 82 mph. I have a castle 240 and numerous 3-s 5000 65c packs. also have neu 1527 1 D, but think its too many kv's. what T.P. motor would you guys recommend? looking for mid 70's speed and decent run-times. thanks
  • StevenBryant
    • Nov 2012
    • 359
    Which rigger are you going to
    Use?
    I converted to and Eagle 45 SG to a Q hydro, it was a very tight build with several mods needed to the hull to take all the electrics and get them into the right place. I run 6s 5000mah cells and I get 8 to 9 laps max out.
    The build was a pig and had taken time to get setup however it is now running really well and handles choppy water really well
    • urbs00007
      • Jun 2011
      • 826
      Use?
      hi, i have built a 45 outrigger with 6-s 4082 1600 kv, this boat is a 90 size rigger. dont know if i can run it on 6-s, but would like to. here is a pic with a 4082 for size comparison. 001.jpg
      • StevenBryant
        • Nov 2012
        • 359
        Now that's a big rigger, you will probably want a 56mm can to power that, and a lot of mah.
        • urbs00007
          • Jun 2011
          • 826
          if i want to run my castle 240, what t.p 56 series motor and how many cells?
            • 8012
            Max voltage for the Castle depends on the exact model but is probably 8S. That's not exactly an outrigger, closer to a sport hydro...meaning heavy. Depending on your performance expectations a 1530-sized motor can work, but so can a 56xx. The latter may work better due to the larger prop it can swing.
            • urbs00007
              • Jun 2011
              • 826
              t.p. motor
              thanks jay. this boat, although a little on the heavy side, will run light on the water because of it's design. I'm looking for around 70 mph sport running with decent run-time. on 8-s with the castle 240 (mamba xl2 water-cooled ) which 56 motor do you recommend ? thanks, john
              • flraptor07
                • Aug 2013
                • 2451
                I'd probably go with the TP 5670 5D 1320kv on 8s it'll be turning about 39,000rpm max, just a hair on the hot side but should be fast propped right.
                • urbs00007
                  • Jun 2011
                  • 826
                  tp motor
                  thanks, any idea on possible run time?
                  • TRUCKPULL
                    • 2971
                    1 mill lap
                    6 lap race
                    Bring it in
                    Larry
                    • ray schrauwen
                      • 9471
                      Sometimes you have to do 8 laps if CD instructs you to stay on the course. I'm not sure if I'm referring to NAMBA or IMPBA.
                      Nortavlag Bulc
                      • JohnZ
                        • May 2010
                        • 254
                        I wish some of these motor manufacturers would include more info with their motors. How many cells? RPM max? Maybe even a few prop recommendations would be helpful.
                        • grsboats
                          • Jul 2012
                          • 975
                          Manufacturers use to set max voltage and rpm for their motors that doesn't mean you have to use it...prop recommendation is something that I would like to hear from them.....forget it..here is the right place to get the right info for what we need.Gill
                          GO FAST AND TURN RIGHT !
                          www.grsboats.com.br
